:camperfam: |
:camperfam: |
While looking for our first camper, the R pod really stood out. About to bite the bullet, looking for a light weight trailer. The wet bath kind of turned us both off. After rethinking we settled on a 2109s minilite. 4 years moved up to a 2511s, still the same tow vehicle F150. Happy we went that route because both MiniLites have been very good to us. Only regret was to not bypass the 2109s and go a little larger ,up to what the tow vehicle could handle. Lifestyle matters too. If we were to travel cross country, would probably rather have the Rpod. That wasn't in the cards then. Now, If we were to, I may look into an F250. Quite a comfort difference between the 2109s and 2511s, but also more weight.
I'm looking to save 2-3 thousand dollars. I can pick up my new RV outside the Manufacturer. Where are the Wildcats made?
Wildcats are made in the Elkhart area, just like the other 95% of RVs. The Wildcat Maxx is made in Oregon and not available East of the Rockies, unless it's a used model. |
We bought a 2017 R-Pod 178. Only two issues with it - the strap that hangs from the frame to support the black tank exit tube was frail - fractured after a few hundred miles. FR fixed under warranty with a strap that had a rubber shock absorber. That lasted a few thousand miles. I finally got a local welding ship to make me a stainless steel strap bent at one end - I put stainless steel pipe clamps around the tube and the bend. Fine now.
The other issue was the converter - It would not charge the battery and it was intermittant -so was hard to pin down. Actually ruined a battery thinking it was fixed once. A friend and I took out the converter board and found a couple of solder connections that were black (had arced). Fixed those and now all is OK.. HOWEVER - never travel without a battery charger that can put out 10 amps. As long as you have place to plug it, you'll always have dc power that way - just clamp it to the battery terminals if you need to. |
