-   -   Slide out power (https://www.forestriverforums.com/forums/f218/slide-out-power-217142.html)
jpsamanka 09-22-2020 06:17 PM
Slide out power
Sorry...new guy here! If this is covered I couldn't find it. Could someone please point me in the right direction. Slide-out was working yesterday. After a very bumpy ride up I95 it quit working. After troubleshooting...motor and switch work. There is no power on the big red wire (#12 I think). I can't find any wire in the fuse panel that big so where does it get its power from?
2015 Rockwood Mini Lite M2109S
007matman 09-22-2020 06:44 PM
No click, no power all together or it clicks but doesn't move?
Mine will get stuck (in a bind I suppose) and not move. If i manually move the override a couple of cranks it'll work then. Just make sure to remove the tool before you hit the button..
jpsamanka 09-22-2020 08:24 PM
I opened the panel and there is no voltage on the red wire. I jumped 12 volts to the switch and it works fine so I need to know where the red wire gets its power because I can't find it in the fuse panel.
01tundra 09-23-2020 09:09 AM
Our trailer has two breakers with manual rest on the frame up by the junction box on the slide side of the trailer. They are located above a cut out access panel in the under belly cover.
One is a 40A which serves the entire trailer, it feeds a 30A that is for the slide.
Bama Rambler 09-23-2020 09:12 AM
There is most likely a breaker on the frame near the front of the RV. There should be a small button on one side of it that's the reset. press it in to reset it.
It'll look like the one below, but it may be metal or plastic.
https://images-na.ssl-images-amazon....AC_SL1500_.jpg
jpsamanka 09-23-2020 10:38 PM
Thanks for the replies! I found it with help from 01tundra and Bama Rambler. It was a 30 amp ATO fuse in a weather proof fuse holder up on the frame rail right next to the 40 amp breaker like Bama posted. It looks like it might have been a repair from the PO as there is a wire nut involved. Anyhow...it’s fixed! The adventures of buying a used RV! Thanks again!
bikendan 09-24-2020 04:27 AM
Originally Posted by jpsamanka (Post 2419967)
Thanks for the replies! I found it with help from 01tundra and Bama Rambler. It was a 30 amp ATO fuse in a weather proof fuse holder up on the frame rail right next to the 40 amp breaker like Bama posted. It looks like it might have been a repair from the PO as there is a wire nut involved. Anyhow...itís fixed! The adventures of buying a used RV! Thanks again!
thanx for letting us know the solution. it may help another member some day.
01tundra 09-24-2020 06:51 AM
They are known to go out so I carry a spare 30A & 40A.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Bama Rambler 09-24-2020 07:25 AM
Thanks much for coming back and letting us know what it was and where you found it.
Our landing gear has a fuse inline like you described. I had a heck of a time finding it in the beginning. It was hidden in the wire loom near the battery.
I carry a pretty large assorted kit of fuses, but replacing the fuse with a breaker like 01 linked above might be a good idea.
01tundra 09-24-2020 09:25 AM
For future reference, here's what they look like on our trailer, the one furthest away in the background (closest to the tongue of the trailer) is the 30A for the slide, the one closer to the silver metal junction box is the 40A for the entire trailer 12VDC system.
The silver junction box is where your 7-way pigtail that connects to the tow vehicle terminates.
Pro tip - If you even have an issue with exterior driving marker lights not working is a group, check for loose wires in the junction box, I've had to fix two already from poor installation from the factory.......:rolleyes:
https://i.imgur.com/pL7QCFQ.jpg
jpsamanka 09-24-2020 07:26 PM
Thanks Tundra...I did not have my phone in my pocket to take a picture and I've had several back surgeries and not even supposed to be on a creeper so I ain't goin back under for a picture! But thats it. My slide power was a plastic ATO fuse holder like the black one in your picture with the red wire. You all have been great! Thanks again! John
nickjmobile 09-28-2020 08:24 AM
I too want to thank you guys, especially Tundra and Bama for the pics. With out shore power I had no lights or anything. I had zero volts DC on the converter DC panel. Yesterday I had located the underbelly access panel and had traced my open to the “terminal block” but had no idea that thing was a fuse. Last night searching through the forums I found this post and those Pics. Talk about excited. First thing this morning I removed the panel and reset the popped fuse. Eureka! You guys are Saints while the guy that buried these fuses in the underbelly is a sadistic Bastid ������ that probably throws kittens in the air for a bit of fun.
