-   Berkshire (https://www.forestriverforums.com/forums/f112/)
-   -   L-sofa heater vent (https://www.forestriverforums.com/forums/f112/l-sofa-heater-vent-217276.html)
wdweldon 09-24-2020 04:41 PM
L-sofa heater vent
I am about to replace the L-Sofa in my 2014 390FL with theatre seating, am I correct in assuming there is only one heater vent which comes out below the current L-Sofa? Any ideas on re-routing the vent?
KPfulltimers 09-26-2020 06:05 AM
In the process...
I too am now replacing the couch. Putting in 2 recliners. Plan is to build a very small side table with the vents installed there. As part of this project I removed the shelf that was behind the couch and replaced it with a chair rail to give better depth to the platform and hence less furniture sticking out into the aisle. I will also be moving the seat belts. We are now parked for the winter, so lots of time to do it right. BTW, found Ashley Composer power recliner that fits through the door! Cheapest overall price was at Goedeker's.
wdweldon 09-28-2020 10:15 AM
Heater vents
Do you know, is that the only output vent(s)? Is the input for the that heater located under the stove?
wdweldon 09-30-2020 02:52 PM
Got it removed
I got the old L-Sofa removed!
