-   Rockwood (https://www.forestriverforums.com/forums/f34/)
-   -   2304KS Slide out (https://www.forestriverforums.com/forums/f34/2304ks-slide-out-217401.html)
Jamesmb53 09-26-2020 11:00 AM
2304KS Slide out
I just purchased a used 2017 Rockwood 2304KS and donít know where the access to the manual slide out closing is. Could someone please point me in the right direction. Thanks!
Bama Rambler 09-26-2020 11:12 AM
It appears that unit has the Schwintek slide mechanism. Please let me know if that's not correct.
Unfortunately it doesn't have a manual operation per-se. You can put the controller in override or you have to disconnect the motors mechanically from the mechanism and push the slide in or out.
Are you having problems with the slide, or do you just want to be ready in case?
Werk 09-26-2020 07:58 PM
This might help. https://www.youtube.com/watch?v=0dIQp0h97xY
Jamesmb53 09-26-2020 09:47 PM
Thanks Bama Rambler. No, not having any problems with the slide out, just wanted to be prepared when and if I do.
Bama Rambler 09-27-2020 09:34 AM
That's a good idea, especially with Schwintek slides as they're not like other slide mechanisms. It's best to figure out how you would handle it when it's not an issue. Of course that's true for all slideout systems, but moreso with the Schwintek.
