-   -   2010 3170 ds stair tread (https://www.forestriverforums.com/forums/f15/2010-3170-ds-stair-tread-217444.html)
sgoharley 09-27-2020 12:59 AM
Need to replace the stair tread in my rig. Anyone have a lead on where to get a replacement stair tread of the compartment over my house batteries
kenandterry 09-27-2020 07:10 AM
I would just check any of the big box stores (Lowe’s, Home Depot) for rubber mats in their flooring section and make my own. Something like this? You don’t want to know how much they’d charge you for the factory runner.
Falconman 09-27-2020 02:10 PM
Bought mine through Home Depot, manufactured by ROPPE.
Do a search at HD, it should pop up.
https://roppe.com/vinyl-tread/
sgoharley 09-27-2020 04:44 PM
Thank you for the input. My step cover is 27 x 10 with a 2 inch lip. I cant find an exact fit but will cut to fit. Thanks again.
Falconman 09-27-2020 04:55 PM
I had to cut mine also, pretty easy to do. I also opted for a lighter color to help to see the steps in low light.
Ladaca 09-30-2020 12:49 AM
I have a 2015 3170DS with the same issue on the battery compartment cover. Looks like HD has a 36" tread that will work. Thanks Falconman for the info.
sgoharley 09-30-2020 01:13 AM
Ladaca if you have a link I would appreciate it. Thanks
Ladaca 09-30-2020 01:17 AM
https://www.homedepot.com/p/ROPPE-Li...P100/204140435. Hope this helps. You will need to change to your local store.
