-   -   Slide out problem (https://www.forestriverforums.com/forums/f229/slide-out-problem-217481.html)
RAY GIB 09-27-2020 01:56 PM
Slide out problem
Our 2004 235 Lexington slide out stopped working and is in. No problems with it before - just didn't move, or attempt to move, when we attempted to put if out. Appears there is no power to the OUT - IN switch on the control console. Can't find a fuse or circuit breaker for this, and can't find a wiring diagram either. Other switches on the console are powered OK. Seems like a no power to motor problem. The wiring to the OUT - IN switch seems capable of handling the amperage required for the motor to run, but perhaps there's a relay involved. Anyone have suggestions?
RAY GIB 10-01-2020 06:46 PM
Slide out
The problem with the slide out not moving is absolutely MY OWN Fault ! When installing two new house batteries I inadvertently attached the lead that runs the slide out to ground on the batteries instead of attaching it to the + or positive side where it should be. After fixing that it works just fine! I shuda known better!
SeaDog 10-02-2020 08:41 AM
Glad you found it and thanks for letting the forum know what you corrected. I have found my smart phone works wonders for helping me remember which wires go where lol
