-   Berkshire (https://www.forestriverforums.com/forums/f112/)
-   -   Slides (https://www.forestriverforums.com/forums/f112/slides-217774.html)
wac1949 10-01-2020 03:01 PM
Slides
I opened the 2 bedroom slides but when I tried to open the 2 kitchen and dining room slides they wouldn't work, and when I tried to close the bedrooms they quit working, tried to find breakers can't locate i have a 2014 Berkshire 39rb
Maingler 10-01-2020 05:27 PM
There is a 125A breaker in the battery compt that feeds the hydraulic pump. Sounds like you have a 12v issue. Check the 125A breaker and see what your voltage is.
wac1949 10-02-2020 01:52 PM
Got power to the pump everything works but the slides1
Maingler 10-02-2020 03:50 PM
Did you try and run it from the mplex panel under the bed?
wac1949 10-02-2020 04:44 PM
Not sure what you mean , i have been on the phone with fr tech 3 times trying to figure out the problem still can't get them to work they didn't mention checking under the bed
Maingler 10-02-2020 05:55 PM
Ok i would like to get you in contact with precision circuits. They can help diagnose.
Maingler 10-05-2020 10:43 AM
Nevermind, i see you have an older unit. Spoke to Mike Winterowd and he said he was working with you.
