-   Salem (https://www.forestriverforums.com/forums/f26/)
-   -   2020 Salem Hemisphere 25rbhl (https://www.forestriverforums.com/forums/f26/2020-salem-hemisphere-25rbhl-219100.html)
{Tpc} 10-21-2020 05:27 AM
Going to winterize this weekend. On my old trailer I had a setup to bypass the water pump from the fresh water tank and pump pink stuff through the lines. Typically Iíd blow the lines out with air and pump pink in.
I feel like my old method may have been overkill. Plus this one doesnít have that option to bypass the fresh water tank.
So Iím looking for a new method. Maybe just blowing the lines out and pouring pink in the traps and black tank/toilet will be sufficient?
I also am not sure about how to place the valves near the hw tank for this.
After the last trip I dumped the hw tank, pulled the low point drains, and opened the fresh water tank valve on the way home to get as much out as I could.
Thoughts? Suggestions? A guide of some sort?
Thanks in advance!
SeaDog 10-21-2020 08:30 AM
Most newer rigs are fitted with a antifreeze pickup to the pump do some checking if you don't have it they are easy to add. Check your HWT for bypass valves.
{Tpc} 10-26-2020 06:23 PM
Ah yes, I found it under the bathroom sink. Itís nice they added that. I found the bypass valves by the hw tank. I was expecting 3 but only found two but seemed to work the same none the less.
