2021 WolfPup 16FQ Water Pump Location(SOLVED)
Anyone know where this is located?
I have drained all my water and really don't feel like filling it just to find it. Then I need to see if I need to buy a winterizing kit. That just throws me. I am a newbie but you would think that should be a gimmie if it has to be winterized. Dan |
Water pump is under the sink behind a panel . 2 square drive screws .
My 2021 16fq has a three way valve at pump inlet with about a24 inch hose attached that will drop right into a jug of rv antifreeze, so no winterizing kit required.
Yup, just found it under the middle sink. Glad that is in there.
