-   Roo | Shamrock (https://www.forestriverforums.com/forums/f46/)
-   -   Is there any way to release the cabinet shelves on the Roo? (https://www.forestriverforums.com/forums/f46/is-there-any-way-to-release-the-cabinet-shelves-on-the-roo-219427.html)
brl1956 10-25-2020 03:36 PM
2 Attachment(s)
The shelves do not want to come out. Just yanking on them won't work.
The bottom of the drawer on the cabinet is loose and is preventing me from closing the door. Would like to remove it from the cabinet and reattach the bottom drawer to make the drawer close.Attachment 241889Attachment 241890
jimbo1710 10-25-2020 06:41 PM
can you take the drawer out and get to it that way?
Scrapper 10-25-2020 11:06 PM
Pull the drawer out as far as it will go. You will see a black plastic clip with a pointed lever in the track attached to the side of the drawer. There is one on each side, one lever lifts up, the other pushes down to release the drawer track from the cabinet track. Pull the drawer out while holding the levers.
Sorry, I don't have pictures of the actual latch.
Pad22 10-26-2020 06:59 AM
If taking the drawer out is what you need, as stated above, there are black plastic levers on the sides of the rails that will allow you to take the drawer out fully. Then you can fix the bottom of the drawer.
More info: https://www.wikihow.com/Remove-Drawers
brl1956 10-26-2020 03:35 PM
Thanks, Scrapper. I knew it would be easy. And then my wife found a video on YouTube that shows you what you are describing.
"How to remove a drawer"
https://youtu.be/DT7A34hPo4w
