-   Cardinal (https://www.forestriverforums.com/forums/f22/)
-   -   hydraulic valve body (https://www.forestriverforums.com/forums/f22/hydraulic-valve-body-219700.html)
donabevd 10-29-2020 07:16 PM
Has anyone moved the hydraulic valve body for the slides to a more convenient spot? Mine is in the front compartment close to the pump. It is a pain to get to so I'm trying to figure out a better spot for it. It looks like a single hydraulic line made up would allow it to be moved to a different spot? Thanks Don :campfire:
SeaDog 10-30-2020 08:29 AM
I have not heard of anyone doing this I think mainly because there should be very little reason to access that part. Something to consider is the farther away from the pump the less pressure the pump will exert on the valve body.
NMWildcat 10-30-2020 08:49 AM
Yep, I don't know that it would be worth it to relocate it. In 9 years I've had to access my valves twice, and once was just to test things out. Mine are also in the basement in a corner behind some coroplast. It is not real easy to get to, but definitely doable.
