-   -   TV Antenna (https://www.forestriverforums.com/forums/f113/tv-antenna-26402.html)
siskman63 07-17-2012 01:24 PM
TV Antenna
Sorry if this is remedial, but I have some questions about the TV antenna system on my 2010 Surveyor 234T Hybrid. I just bought it new, and it's great. I can't figure out if the TV antenna is for analog or digital TV. If I buy a new flat screen TV, do I need to get some sort of analog to digital converter? I have an old analog tv that I plugged into the antenna jack (I think it's the antenna jack), raised the antenna, and tried to get a signal, any signal. Nothing. Then I installed a digital to analog converter, and it simply says "no signal" from antenna.
Should I be able to plug in a new flat digital tv into the antenna jack, unflold the antenna and watch tv, or is there something else I need to do?
Any info would be great.
TURBS 07-17-2012 01:27 PM
If your tv is digital nothing else is needed.
If its not u need a converter box.
Antenna same either way
TURBS 07-17-2012 01:28 PM
When u hook up tv do a channel search.
May have to rotate antenna to get more stations.
I get nearly 35 where I'm at.
Herk7769 07-17-2012 01:28 PM
Search on "Winegard" and "Wingman" for a long discussion on optimum TV viewing in the digital age.
Acableguy06 07-17-2012 01:28 PM
The old analog TV will not be able to get anything. You should have been able to get something off the converter box though. Did you run the auto program on it? And yes a new TV with a hd or digital tuner should work just fine with your antenna. Just hook it up run the auto program and see what you get in, sometimes you may have to rotate the antenna to get some channels in better.
MtnGuy 07-17-2012 02:55 PM
The antennae booster must be on to receive over the air transmissions. I didn't see where the OP mentioned that.
trudinator 07-17-2012 03:39 PM
I have a stupid question. We have the wineguard antenna with the wingman booster. I've read on these forums that once you install the wingman, the antenna becomes a directional antenna and has to be directed in the direction of the station you're trying to get. Here's my stupid question.....how do I know which side of the antenna is supposed to be pointing at the station??? I'll plead ignorance, but my DH doesn't have an excuse. :roflblack:
TURBS 07-17-2012 03:42 PM
The side that looks wrong ;)
MtnGuy 07-17-2012 03:48 PM
You should point the Wingman towards the station antennae.
When setting up at a new location, I do 3 channel searches with the antennae pointed about every 120......seems to work well. The missus also has a phone app that shows where the local stations are located.
Herk7769 07-17-2012 03:49 PM
The elements of the wingman point to the station like an arrow.
MtnGuy 07-17-2012 03:50 PM
Beat you by 1 minute, Lou. :D
SimchaSabre 07-17-2012 03:58 PM
I use the King Control Dig TV Finder (Amazon link)
https://ecx.images-amazon.com/images/...500_AA300_.jpg
Just rotate the antenna and peak the signal strength. Works great...especially in fringe areas
Oakman 07-17-2012 04:03 PM
With or without the wingman, it has always helped to point the antenna in the direction of the station source. That's why the antenna was always on a rotating ring long before digital TV came on the scene.
TURBS 07-17-2012 04:08 PM
I think she wants to know which side of the antenna points which way.
Herk7769 07-17-2012 06:43 PM
5 Attachment(s)
Well, I guess no one wants to read the old posts.
Cliffs Notes Version:
Old "BatWing" type Antennas
VHF directional - Wings need to be 90 degrees to station and as such were directional. Front lobe of antenna was the side of the wings with the white box (amplifier) on it. Much longer range than UHF channels.
UHF - Omnidirectional - Like the old "wire loop" of the past, it is a circle of wire inside the white amp case. VERY short range.
Digital did not change the way the antenna works. Still directional for VHF digital channels. (yes Virginia, there are still digital VHF channels.)
However with the advent of digital programming, the station frequencies could be packed closer together and most NEW high definition station broadcasts are in the UHF range since there was more room there.
This caused a problem because most UHF antennas were pretty rudimentary.
So while you could receive a VHF station, the collocated UHF high def channel won't come in. The "fix" was adding focusing elements on the UHF antenna that act like a magnifying glass and "bend" the incoming weaker signals (too weak to display on the digital TV) and focus it onto the internal loop antenna in the white amp head.
This almost doubles the distance you can receive UHF High Def channels. The downside is the "focus" issue. Like a solar magnifying glass, the lens has to point the correct way. Holding a burning lens sideways will not cook any ants. Same with the Wingman booster; it has to point to the broadcast towers to work.
Picture an airplane. The "cockpit" is the white amp head with Wingman elements and the wings of the plane are the bat wings. The nose of the plane must fly to the station to get the highest signal.
VinceU 07-17-2012 07:04 PM
Don't think anyone answered your orig. question completely. The wall plate holding the TV antenna cable recpt, ie wall plate has a small black button with green indicating light. Press button till light is green and this turns on amp in the roof element. Follow balance of instructions......
vizsla owner 08-13-2012 02:00 PM
I just look at the camper next to me or which ever is close by that has the antenna up. Usually the direction they are pointing is the direction I have to point also.
Herk7769 08-13-2012 02:39 PM
Last campground I was at NO ONE was pointed at the antenna farm. They were all pointed at the nearby city. They were shocked when I was picking up 6 more stations than they were.
AntennaWeb - Home ROCKS.
