-   -   TV on Generator or Battery??? (https://www.forestriverforums.com/forums/f113/tv-on-generator-or-battery-26712.html)
FarFromStock 07-24-2012 07:18 AM
My husband and I are having a discussion...and I figured I'd ask the folks who have most likely experienced something similar...
We want to get a small TV for the A127TH...but the question is...when we are not hooked to shore power, is it more efficient to run the TV using the generator power or using the 12V battery? The TV we are looking at can run off either 12VDC or 110VAC, but we are wondering which is more efficient????
Anyone have any thoughts/recommendations?
Thank you!!!!!
Debbie
TURBS 07-24-2012 07:23 AM
You need to know how many 12v amps tv draws to get a better idea.
Keep in mind after watching tv on battery you still have to charge battery via gennie.
Unless you have some other method.
Ron
MtnGuy 07-24-2012 07:56 AM
Also depends on what type of generator. If you have an inverter generator that produces "clean" electricity, then a generator is OK. If you have a construction generator with "dirty" power, then you might just run your TV on battery only.
Like Turbo stated, you would need some way to eventually charge the battery.
bikendan 07-24-2012 09:35 AM
most campgrounds have no generators after 8pm, so most of us recommend using an inverter.
but you'll need two batteries, that you recharge with the generator the next day.
FarFromStock 07-24-2012 11:42 AM
Thank you all for your inputs!!!!! I do appreciate it!!!
Sounds like the most efficient power source for the tv is the generator...but only until 8pm, then it'll be switched to the battery. Until we get a solar pad hooked up we'll charge via generator while camped, otherwise it'll be from the truck. We have a Honda EU2000 - clean electricity.
TURBS 07-24-2012 12:05 PM
Good luck!
KyDan 07-24-2012 12:09 PM
We use a cigarette socket inverter to power our TV.
We can watch a DVD movie each nite for 3 nites.
After that we're pretty low on battery power.
I have only 2 regular 12v marine/crank/deep cycle batteries.
Nothing exotic.
We typically run the Honda for a couple hours after day 3.
This would be mid afternoon during "margarita hour".
If I'm only staying 3 days then we don't even start it.
YMMV.
Herk7769 07-25-2012 06:26 AM
Thank you!!!!!
Debbie
Debbie,
From my reading and experience, given the choice, the 12 volt power directly from the battery is slightly more efficient than 120 AC using the battery to power an inverter to make AC. There is no wasted power in the conversion process.
Running the generator is a noisy way to watch TV, IMO. Better to watch TV quietly on either the battery or the inverter (powered by the battery) and then charge it using the generator and a dedicated battery charger (not the converter in the camper).
FarFromStock 07-25-2012 06:51 AM
Thanks everyone!!! All great feedback!!! :-)
TURBS 07-25-2012 07:05 AM
Good luck!
KyDan 07-25-2012 07:13 AM
I agree 100%
