-   -   Starting Fridge On Propane (https://www.forestriverforums.com/forums/f113/starting-fridge-on-propane-27709.html)
Chillywillie 08-12-2012 10:30 PM
Hi guys. Just joined the group and a new rver. I bought a 2001 Flagstaff 21fb and I don't see where the pilot light is on the fridge is. Does it have an auto start pilot light or am I just not finding it yet. Thanks in advance Chillywillie. From the foothills of the rockies in Calgary
Terier 08-12-2012 10:33 PM
Welcome to the forums! Do you know what brand & model number your fridge is?
Chuckinca 08-12-2012 10:42 PM
Our unit is two yrs old - the fridge has two "on" settings, gas and auto. Put it in auto and if there is no 120 VAC electric power it starts automatically with gas (as long as the propane tank valve is open). No pilot light involved.
Tincup13 08-13-2012 08:43 PM
My 2011 has 2 settings gas and auto. Turn on propane, pilot lights automatically uses electric first then gas if no electric. Outside rv side by fridge u hear the pilot lighting inside the vent
Fire Instructor 08-13-2012 09:52 PM
My old '98 Jayco PUP had a small "sight-glass" inside, which allowed you to see the lit pilot, so that you could verify from the inside that it is on. My two units since then, have both had an inside trouble light, which let you know if the fridge WASN'T working. Like TinCup said, if you want to be sure, go outside by the vent and listen closely.
bikendan 08-13-2012 11:12 PM
a pic of your fridge' s button/controls would help.
also, make and model of fridge would also help.
newer fridges have auto lighting feature.
not sure if that was around in 2001.
Triguy 08-14-2012 09:52 AM
First of all - Welcome to Forest River Forums! Hope we can help you.
You really do need to give us the make and model number of the fridge (e.g., Dometic DM2652).
As Bikendan said, your camper might be gas/elec but it might not considering its age. The newer Flagstaff Micro lites are gas/elec.
If it has a control panel that looks like this one ...
https://www.forestriverforums.com/for...1&d=1309348913
Than, the following applies...
To allow the fridge to choose between AC or Gas:
  • On/Off button is depressed to "on"
  • Gas button needs to be pushed in.
  • The "auto" light will light up and it will choose AC first and then gas if AC is unavailable.
If you wanted gas only and not AC:
  • On/off button is depressed to "on"
  • Gas button needs to be out.
  • The "auto" light will not light up.
The gas button "out" effectively locks out the electric.
