-   -   Sheared Bolt on Slide Out (https://www.forestriverforums.com/forums/f229/sheared-bolt-on-slide-out-5620.html)
rockwood06 03-18-2010 07:42 PM
My problem came up on another thread. I posted a pic to help some one Identify the tool and the motor for the slide out incase they had no power, they wanted to know now to operate the slide out. After I posted the pic Chevey02 noticed that I had a sheared bolt on my slide out right on the shaft of the motor. Well today I installed four new bolts #8's, I was not able to get stainless steel. After installing the new bolts I operated the slide out with the hand crank so that I could inspect all of the moving part, I turn the crank and made three revolutions the next thing I knew, I heard a pop and one of the new bolts snaped and shot out about three feet just missing my head, I stop and came in the house and called the service department the camper is going in to the shop tomorrow morning. I installed one of the old bolts and handled the slide out with TLC intil the slide out was completely in. I posted pic of the bolts but sorry they are fuzzy. The bolt on the top is the new one, and the last one at the bottom is the one that snaped the first time that Chevy02 saw. There was another member that replied as will and had explained that he had the same problem and he gave me some added advise, I am sorry at this point I can not remember the screen name, but I would like to thank both of them for bring this up I could have had a real mess on my hands with a jamed slide out.....:thumbsup::thumbsup:
chevy02 03-18-2010 08:17 PM
Did you try the hardened bolts they are kinda bronzeish looking if that even a word
midnightpumpkin 03-19-2010 12:56 AM
Here ya go.
https://rocky06fs.forumco.com/topic~TOPIC_ID~680.asp
Don't use stainless steel bolts in this application. They have very poor tensile strength. You need to use grade 8 bolts.
John U
BTW I have had no more bolt problems since I applied this fix.
rockwood06 03-19-2010 12:24 PM
Yes, it is a #8, and it was a bronzeish in color 6 marks on the head of the bolt. The pic I posted of the bolts was bad. I toke the camper to the shop early this morning and I am waiting to hear what they find. Like I said, they had to make adjustments to the slide out last Spring but the slide out was not operated that much because we were on a seasonal site. I have had some problem over time with the left side of my camper, I had to take it in for warrenty work when I first bought the camper, the brakes on the left side kept locking up and damage the brake shoes, while they were changing out the shoes the dropped my camper off of the jack and the camper bottom must have come down on top of the jack and damaged the under bell and they had to replace the power jack. The front of the camper was not attached to a hitch on a vehicle, it was on the ground and when the camper was jacked up it slid off of the jack. I can't say if this has anything to do with anything, but It makes me wonder.
PumaPro 03-19-2010 08:00 PM
Originally Posted by midnightpumpkin (Post 40617)
Here ya go.
John U
I found grade 5 to work better. There is some play in the shaft, and that play tends the hard-but-brittle grade 8 to break. The grade 5 will flex a little. All trailer hitches use grade 5 also, believe it or not. Each has 3 marks on the head.
chevy02 03-19-2010 09:38 PM
HMMM grade 5 i will have to give that a try also
