-   General Motorhome Discussion (https://www.forestriverforums.com/forums/f4/)
-   -   Wondering if safe to use the tow haul switch,when driving on the mountains without tow (https://www.forestriverforums.com/forums/f4/wondering-if-safe-to-use-the-tow-haul-switch-when-driving-on-the-mountains-without-tow-67023.html)
capitan 08-24-2014 02:04 AM
2005 sunseeker 29le
rana 08-24-2014 02:52 AM
Just to clarify: You are asking if it's okay to use tow mode in the mountains without a tow vehicle, right? To get more power running up the hills right. Since it basically just changes your shift patterns and helps by engaging the engine break mode I certainly don't see why not... other than it will undoubtedly affect your mileage.
capitan 08-24-2014 09:12 AM
Yes Yarome, the only reason I ask is because when I was breaking going down, my whole front end of the motorhome starts shaking.
rana 08-24-2014 09:14 AM
Even downshifting manually? (engine brake)
I was just asking because if you were, then there could be something else going on.. like poor alignment. If you weren't and just using the pedal brake then that is pretty common. Try downshifting manually, or engage the tow mode.
capitan 08-24-2014 09:28 AM
It's an automatic transmission, 6.0 v8 vortec engine. And it has a tow haul switch. It does this only when breaking hard down the mountains, I realize this is no good, but I had to due to wild animals
rana 08-24-2014 09:41 AM
I knew it was an automatic, but you also should have a 3rd 2nd and 1st gear you can engage while driving to limit your engine to a lower gear.. or engine brake. It helps to cut down on the amount of pedal brake you need to apply. That's basically what your tow mode switch does for you automatically when you are going downhill. I don't know how far tow mode will downshift you though. Never tried it, but you can always do it manually.
Nacho 08-24-2014 12:35 PM
Sounds like your rotors may be warped. Had it happen to my pickup in the early spring. Every time I would go to break the front of my pickup would shake. Put new brakes and rotors and the shaking stopped.
Dodge Guy 08-24-2014 01:30 PM
Whenever you start the MH engage Tow/Haul! it was designed for heavy loads....and a class C is a heavy load 100% of the time. when they build these things for use in RV/bus applications I wish the chassis manuf would program the Tow/Haul to always be on.
And Yes, get those brakes fixed! sounds like you`ve been riding the brakes coming down the hills/mountains! use TH or downshift and let the trans do the braking! (TH will automatically downshift the trans when the brakes are touched).
Ford Idaho 08-24-2014 01:34 PM
Glazed brake pads?
rana 08-24-2014 01:38 PM
Originally Posted by Ford Idaho (Post 686553)
Glazed brake pads?
More than likely. Warped rotors he would feel at lower speeds on flat roads. Downhill in a class C without downshifting at regular highway speeds... oh yeah.. there's ya some hot feets. ;)
Ford Idaho 08-24-2014 01:54 PM
Yes, a light down pressure on the pedal will make them pads looks like a mirror.
