Water Heater anode
The camper is brand new this last September. Probably need to replace. We have bad hard water here. Attachment 66182
Sent from my iPhone using Forest River Forums |
Glass bead blasting will make it look like new with the exception of the crevices, but the glass beads even clean them out. I clean mine every time I remove it, wrap the threads with Teflon tape and re-install it.
I was surprised how it looks for such a short time used. I'll use next year then start replacing every spring
Unless your using the water heater all summer long you should get at least 2 summers out of one. Take it out every fall and clean threads and put new Teflon tape on every fall, while its out flush the water heater and clean all the residue out of the water heater .
2 Attachment(s)
I don't even clean mine; just close the bypass valves; drain and flush out the tank; tape up the threads and screw it right back in. |
I recommend teflon tape or oatey great white pipe dope with teflon.
You don't want the anode rusting threads and sticking in there! It has happened. Even with tape there will be some metal to metal contact and that's all that's needed. I put liberal amount of oatey pipe dope on mine every time I drain and replace it. It still gets eaten away so I know it's making contact. Just drained and re-installed mine yesterday.... |
My anode was taped when I took it out. I'll take again. I've had issues years ago when I had my first TT to winterize. When several years on a small unit we just had to park.
Thanks for tips. Was going to squeeze in another weekend but seems winter wants to come to southern Indiana Sent from my iPhone using Forest River Forums |
Agree totally. |
my old one wasn't taped and it had rusted in but I was able to get it out. I taped it's replacement and never had a leak and it came out easy.
Maybe you should read up on the metal to metal contact for them to truly protect. To each his own, and mine do not leak. |
The manufacturer states to use teflon tape or sealant suitable for potable water in their installation directions on the back of all their anodes packaging. The pic shown is for an aluminum one, but the magnesiums state the same.
I have also purchased anodes that came with teflon tape in the packaging. All of my anodes have sacrificed themselves accordingly. https://galleryplus.ebayimg.com/ws/we.../1000x1000.jpg |
Not using Teflon tape or Teflon pipe dope may result in thread corrosion and make removal of the anode more difficult. Recommending someone not follow the manufacture's instructions does no one any good. If the Teflon tape "bunches up" you are wrapping it on the threads backwards. https://www.youtube.com/watch?v=G3LMrn750Ys |
