-   -   Brake-Away Switch (https://www.forestriverforums.com/forums/f2/brake-away-switch-73505.html)
Chillbilly 01-06-2015 07:25 PM
Brake-Away Switch
OK - I DID IT! I pulled out from under my 5th wheel without unhooking my brake-away switch. It ripped the brake-away switch completely off the hitch, leaving a couple of wires hanging there. I would have expected the break-away wire to have been ripped from the switch but that was not the case. Anyway, I am installing a new break-away switch onto the hitch. My question is, are the trailer brakes on when the switch is open or closed? In other words, right now the wires are separated - so the switch would be open - are the trailer brakes on or off.
fonzie 01-06-2015 07:32 PM
Trailer brakes are on when switch is closed, so now with wires separated the trailer brakes are off........
Ford Idaho 01-06-2015 07:34 PM
https://www.google.com/url?sa=t&rct=j...83134100,d.cGU
The break away switch should be wired so that it is a normally open circuit ... the pin is pulled, the circuit closes, allowing voltage to travel to the trailer brakes.
