-   Modifications and Updates (https://www.forestriverforums.com/forums/f68/)
-   -   Rear Camera install question (https://www.forestriverforums.com/forums/f68/rear-camera-install-question-83044.html)
Michigan-traveler 05-25-2015 10:30 AM
I am ready to install a Voyager rear camera, which requires that I tie the wiring into a rear running light. I am not sure how the running light lens comes off. There is some sealant around it . Do I just clean the sealant off of the lens, and will it just snap off? Thank-you for any help you can offer.
DiverDennis 05-25-2015 04:14 PM
Don't know if you will be able to tap into the wires from inside the fixture. I Just installed a license plate camera ($40 eBay) and had to tie into the rear running light with butt splices and heat shrink. Hope this helps.
https://www.forestriverforums.com/att...9a1f3dfe4f.jpg
https://www.forestriverforums.com/att...f79bb7e54a.jpg
https://www.forestriverforums.com/att...159a3ecda9.jpg
jgahlhoff 05-25-2015 04:18 PM
Yes it should just pop off. You may need a butter knife or something similar .
Yooper mom troll dad 07-18-2015 09:43 AM
Driver Dennis has the right idea, Tap into the wiring harness, use butt splice connectors and protect it with shrink tube, he did a very good job illustrating the install.
itgoes211 07-18-2015 10:56 AM
Diverdennis, how does the monitor receive video signal from the camera? I just see two wires for power.
Brewhedd 07-20-2015 07:48 AM
Just bought a rear view camera and looking at the running light the lens pops off with a small screwdriver. However, I don't think just removing the lens is going to provide access to the wires. The base is going to have to come off which means cutting the caulking. I assume there is a hole behind it and I'm hoping there is enough wire there to pull some out. If possible I'm going to use small waterproof scotch lock connectors then drill a hole in the bottom of the lens for the wires to exit.
DiverDennis 07-21-2015 09:03 PM
It transmits on a 2.4G wireless signal.
