-   -   Can I stand on my slide out roof? (https://www.forestriverforums.com/forums/f229/can-i-stand-on-my-slide-out-roof-8364.html)
Grounded 09-19-2010 10:31 AM
I need to reseal the outer edge of the slide out roof. Is it safe to stand on the thing? I can't figure out any other way to get to it.
pondlady 09-19-2010 10:33 AM
Can you put the slide in almost all the way, use a step ladder and seal it that way? Seems like that would be safer.
Mr. Black 09-19-2010 11:01 AM
In most cases yes.
In my case I do.
dezolen 09-19-2010 03:39 PM
I would not as I found my 12'slide was bowed about 1" in the mid section. I reinforced the roof behind the decorative trim.
Not sure if this was caused by standing on open edge from the exterior or not but it would make sense.
milzat 09-19-2010 10:14 PM
Yep, you sure can.
Waite. How big a-boy are you? :rolleyes:
dezolen 09-20-2010 06:18 AM
Originally Posted by milzat (Post 63189)
Yep, you sure can.
That's right. You can do anything you want. Whether any damage is incurred is another story. 12' span,200# on aluminium framed non supported roof. You do the math.
08flagvlite 09-20-2010 07:48 AM
If you have a teenage son as I do, get them to do it-(140 lbs) versus 250! (In my case)! Also, laying down on the roof will distribute that weight better. Randy
jaxfl 09-20-2010 08:16 AM
The best one of these suggestions to to only move the slide out a little and reseal it that way, you dont need it out all the way to do the job.
Grounded 09-20-2010 09:27 AM
Well since I go about 230 maybe I'll explore the issue a little more.
