-   -   Rockwood Slide Inop (https://www.forestriverforums.com/forums/f229/rockwood-slide-inop-86952.html)
kharris111 07-08-2015 10:59 AM
Rockwood Slide Inop
I have a 2008 Rockwood 8317 SS. Last time out, the slide retracted but did not click per usual. Since then the switch doesn't respond. Can't hear anything when the switch is activated. I had to use the manual hand crank to operate the slide. All fuses are good. Tried a different battery and no luck.
fonzie 07-08-2015 11:52 AM
Possibly a fuse or mini-breaker underneath trailer near tongue that is burnt or tripped. Re-set by pushing small black button (if you have) or change fuse.
kharris111 07-08-2015 02:09 PM
Fonze, thanks for the suggestion. I didn't know there was an external relay. I'll take a look.
