-   -   slideout warning! (https://www.forestriverforums.com/forums/f229/slideout-warning-9060.html)
G.A. Kelley 10-28-2010 04:28 PM
slideout warning!
If you have a slideout with the retractable power cord on a 1/4 inch steel support rod check for rubs in open and closed position mine was rubbing the copper propane lines to the point of almost leaking !
It was repaired with 1/2 inch pvc conduit sleve over the rod
a rubber hose sleve for the copper and 2 wire ties
Not to mention the brake brakeaway switch thatwas TAPED ON
YOUR BEST FRIEND IS A GARAGE CREAPER AND A THROUGH INSPECTION
2007 cherokee 30f
ohiodude 10-28-2010 07:13 PM
we had a slider bend the hydrolic ram, and the slider was stuck in the open position. anyone else have the same issue?
Boyd 10-28-2010 07:25 PM
Big Bang Theory Exposed
2007 cherokee 30f
I don't know what kind of rig you have but that sure sounds like a definite RECALL issue. You and your neighbors life are totally compromised with potential leaking propane.
