-   -   Levelling jack slips down gradually (https://www.forestriverforums.com/forums/f110/levelling-jack-slips-down-gradually-97352.html)
dashonthedash 12-03-2015 02:53 PM
This has been happening for some time, but I have generally ignored it, since it hasn't affected the operation of the jacks, or the ability to level, and I have been able to retract it every few weeks or so, as needed. Lately, it has been getting worse, dropping a bit more quickly. My dealer once told me that it needed a whole new jack (he didn't actually look at it), but I think there could be another problem. If I remember correctly, the jacks are held in retracted position by hydraulic pressure. If the pressure is weakened, the jack could drop. The affected jack is the one farthest from the pump/tank, which is what made me think of this. Could a weak pump or a partially blocked hose cause this to happen? I don't think there is a leak, as my fluid level hasn't dropped, and I haven't found fluid dripping from anywhere.
VinceU 12-03-2015 07:54 PM
Each jack has one piston per. It's double sealed with o'rings. Pressure is applied to both sides when the jack is positioned. This is a balanced system. However if the o'rings leak even slightly the weight of the coach will cause the piston to drop with no change in system pressure and thus your condition.
