I'm assuming this is a Whirlpool residential refrigerator?
If so, sounds as if you have power (light is on) and you hear something running. (maybe compressor not motor?)
That typically indicates an internal problem which will likely require removal of the refrigerator. To replace some residential refrigerators in R/Vs, a slide out needs to be removed as they will not come out/go in the door.
2022 Cedar Creek 345IK 5th Wheel•Solar & Inverter•2024 Ford F-Series SCREW•7.3L•4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=90
