Old 02-16-2021, 05:44 PM   #1
Softstart for AC unit
Has anyone ever used the softstart product for their RV AC. We live in Ontario Canada and until covid is in the rear view we will be spending out summers on Manitoulin Island. We are on a 20 circuit and not able to use our AC. We don't need it alot as the nights are generally chilly being right on Lake Huron. The days do get hot and would like to use this product to run ac through the day at times. Anyone use it when power supply is an issue
Thanks from the snowy north.
Spragueman is offline   Reply With Quote
Old 02-16-2021, 06:00 PM   #2
Desert Boat's Avatar
We used the microaire 364 in our TT for several years. We never ran off generator, but lots of folks say this will allow operation from a smaller generator. They claim you can run two ACs off a 30 amp cord if both have the microair.
microair.net
2021 Isata 5 28ss 4x2 / 2020 JLU Rubicon
Prior: 2016 Lance 1995 / Ram 1500 Eco Diesel
2012 Lance 1575 / 2015 Jeep JKU Rubicon
Desert Boat is offline   Reply With Quote
Old 02-16-2021, 06:36 PM   #3
Thanks desert boat. The micro air is a little cheaper too.
Old 02-16-2021, 07:49 PM   #4
dbutton's Avatar
I just bought 2 from MicroAir.net, Easy Start 364. Use code KYD1 for a $25.00 discount off each one at checkout.
The code is from Keep Your Dream YoutTube channel.
David & Mary Button - Ithaca NY
2011 Dynaquest XL 36' Freightliner
Cummins ISC 330HP/1000TQ
dbutton is offline   Reply With Quote
Old 02-16-2021, 07:53 PM   #5
dbutton's Avatar
I just bought 2 from MicroAir.net, Easy Start or Soft Start #364. Use code KYD1 for a $25.00 discount off each one at checkout.
The code is from Keep Your Dream YouTube channel.
Old 02-17-2021, 10:52 AM   #6
SetauketJeff's Avatar
This looks like a simple kick start capacitor. All central AC units have these. I don't see why you can't wire one in yourself and install it in a waterproof gang box. Home Dopey and Blows both carry these capacitors as well as the waterproof gang boxes. Should cost under $30 to make it yourself. https://www.homedepot.com/s/HVAC%2520capacitor?NCNI-5
Every stop light is a staging light!
2021 Wolf Pup 16FQ.
2022 Tacoma TRD 4x4 Offroad. Husky Centerline TS32215 WDH Round Bar 400-600Lbs.
CURT 51180 Echo Bluetooth Brake Controller (Love it!).
2004 Ford F-150 STX 4X4 Tow Package, 273K For Pulling TT in the sand.
SetauketJeff is offline   Reply With Quote
Old 02-17-2021, 11:04 AM   #7
The difference between a "kick start capacitor" and the MicroAire unit is that the MicroAire unit ramps up the starting current until the motor is going fast enough to switch to the "Run Capacitor". MicroAire has posted a video that shows how their unit reduces the starting inrush significantly while the "kick start" capacitor actually can increase the inrush.
The only thing the capacitor does is shorten the amount of time the current flows but at the expense of higher current.
I put a MicroAire unit in my A/C and my generator loves me for it.
"A wise man can change his mind. A fool never will." (Japanese Proverb)
"You only grow old when you run out of new things to do"
2018 Flagstaff Micro Lite 25BDS
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 02-17-2021, 11:14 AM   #8
SailorSam20500's Avatar
From my reading, the MicroAir requires 5 starts on shore power after installation as the unit learns the requirements for your AC unit. The SoftStart for Southwire does not have the learning requirement. So, MicroAir might have a lower power draw during startup than the SoftStart which must use a generic ramp profile.
Mike Sokol has done an investigation of the SoftStart unit and shows the current draw at startup of that unit. As I recall without the Softstart there was actually a max current draw of over 45 amps. With the unit, max draw was around 20 amps. It takes about 14 amps to keep the AC unit running once started.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 02-17-2021, 11:23 AM   #9
So you're saying that they have a Motor Run Capacitor in them and not a kick start? Motor Run Capacitors will run you a few $ more $15 - $100 depending upon the range of operation.
Personally we ran our TT off of a 15amp outlet during a two day blackout this past summer (this was before I installed a 30amp 125 outlet). Our home has a standby generator which runs our entire home (well pump too), with the exception of our 2ton and 3ton AC units. We had the AC (Coleman Mach 3 Plus AC 48000 series), 32" TV and a few lights on and had no issues. Luckily we were able to keep cool until the power went back on.
2021 Wolf Pup 16FQ.
Old 02-17-2021, 11:26 AM   #10
Thank-you for the reply. I do appreciate
Old 02-17-2021, 11:38 AM   #11
My understanding, most recent RV AC units come with a kick start capacitor. The MicroAir and SoftStart units replace them with a computer control mechanism. To get the AC unit started, the kickstart quickly sucks in a bunch of current and then dumps it out to boost the current flow to the motor. The first step exceeds the current capacity of the smaller generators and causes them to drop out.
As side benefits of the starters, the slower ramp up of the motor significantly lowers bang noise when the AC starts up. There is a potential to extend the life of the unit because of the lowered stresses.
Al
Old 02-17-2021, 11:59 AM   #12
No, both start and run capacitors that were installed in the factory are still there. The MicroAire unit merely modifies how the current passes from start capacitor to motor.
Without the MicroAire my 3500 watt generator had to "grunt" a little when starting the A/C unit. It could do the job OK but with the MicroAire the generator shows far less signs of load.
Sounds like you have a much larger generator that is able to handle surge currents better than the most common ones used for camping.
Old 02-17-2021, 12:29 PM   #13
TitanMike,
Got ya, thanks. CIRCA 1978 Onan commercial generator (Gasoline, LP, NG) is an historic workhorse. Installed when the house was built. But not 50 years old like my Super Bee <<<.
2021 Wolf Pup 16FQ.
Old 02-17-2021, 02:29 PM   #14
Running a 15 btu AC (SoftStart installed) with a Westinghouse XI 2200 - 1800 net without any problem- not sure I could run the micro & AC at the same time but not a problem to alternate - trust me when I say the SoftStart is a lot more than a simple capacitor
Steve & Cody the Wonder Dog (he wonders if he is a dog or not)
Forest River - Rockwood
2018 Ultra Lite 2040WS 5th wh
2020 Ram 1500 Eco Diesel Curt Hitch - 392 rear end
sasch is offline   Reply With Quote
Old 02-17-2021, 02:44 PM   #15
Have a '19 Rockwood 2104s with single AC unit. Would my Honda 2000i run the single AC if I installed either of the softstart systems referenced in this thread?
Normutah is offline   Reply With Quote
Old 02-17-2021, 02:58 PM   #16
IMO the SoftStart 364 YES they are very helpful if you call them I’m sure their answer will also be yes - I think the manufacturer is MicroAir.
Old 02-17-2021, 03:01 PM   #17
I'd say yes too. It's one of MicroAire's advertising points.
Old 02-17-2021, 03:28 PM   #18
I added a hard start capacitor and fan relay. It smoothed out the initial bang at startup, I think the capacitor knocked off ~5amps and delaying the fan also helped. My 15k a/c unit struggled to start with a single Yamaha 2000 but YMMV. The route I took was inexpensive and easy to install. Got the info off this message board from more senior members. It's worth a look, even for just the fan delay if you go another route for the capacitor.
http://www.forestriverforums.com/for...ch-100154.html
http://www.forestriverforums.com/for...ac-100548.html
https://youtu.be/NVkCjPh7Nd8
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
CraigBean7672 is offline   Reply With Quote
Old 02-17-2021, 03:33 PM   #19
I've heard some reports that these reduce the efficiency of the A/C. Since I live in Texas, that would be an issue if that's true. Can anyone confirm if this is true or not?
Rockwood Ultra Light 2304DS, towed by 2018 Ram Cummins Diesel 2500 4x4
RobbieH is offline   Reply With Quote
Old 02-17-2021, 04:04 PM   #20
Swampy's Avatar
Those are Hard Start Capacitors, meant for a motor that won't turn under it's own power without a hard push.The capacitor merely shifts the voltage 90 degrees and dumps it into the motor at startup. All the hard starters do is dump a little more Amps on the Compressor to get it started rotating and likely will not work with a small generator if the generator won't run the A/C to start with. Soft Starters actually slowly ramp up the current until the compressor is running full throttle at which point the current stops increasing and stabilizes. The generator will not bog down and quit
if the running current is around 15Amps and you have shaved the 40 to 50Amp compressor spike from the motor with the soft starter. No, you won't find a reduced voltage motor starter at HD or Lowes ... perhaps an electrical supply house can help you out or figure out what you want and buy direct from the manufacturer.
Jim (Swampy), Susie, Jimmy & The Chihuahua Crew
2008 Chevy Silverado LS, 4.3L, V6, 2WD, 3.23:1
2014 287 BHBE; 1981 JayRaven: Predator 3500i - Call Home Pearl River, Louisiana. on The Honey Island Swamp
https://www.forestriverforums.com/at...pic81807_1.gif
Swampy is offline   Reply With Quote
