dhatfield6
Advanced Member
Start from the beginning. I may have dry fried the element because I know the tank was dry when camping last week. I hooked up city water as usual, and as usual, removed the outside heater cover and flipped the switch to on. Remembering as soon as I made the mistake I flipped it back off. Long story short we used the boathouse the rest of the weekend! After the tank filled and the air was purged from both hot & cold lines I turned the electric switch back on. When I was informed of no hot water I found the the on/off rocker switch froze in the on position. At that point I switched the inside breaker off for the electric element.
Once home I ordered the switch and element, assuming this would cure the problem. Only to find out that the element did not burn open, (both new & old elements ohm'ed the same at 10.5) but what I found was the the connector melted on the hi-limit thermostat. Same wire from the switch!
Could energizing the element without it being completely submerged have caused this? Or could I have something else going on?
