For Sale: 2012 Jeep Wrangler Sahara
chunker21
Jan 21, 2018
202
2012 Jeep Wrangler JK Sahara door 3.6l V 6 engine, 6 speed manual transmission. Both tops, removable hard and soft. Soft top appears to have never been used. Air conditioning, power window/locks, Bluetooth, and 2 OEM keys. Jeep is of Canadian origin and as such the odometer and primary gage for the speedometer is in kilometers. The left dash display can be set for US or metric readings. Odometer mileages can NOT be set for miles. I have some of the earlier servicing records provided by the previous owner. Servicing performed at a Canadian dealership. Most of the servicing since my purchase has been performed by me except for a couple of tow equipment related parts.
Notable repairs maintenance. Oil changed periodically, last change 9 29 19 88,420 Mobil 1 5W 30 . Replace front brake calipers, rotors and pads, front brake lines, and wheel speed sensors, 8 8 19 87088 , Oil and filers 7 25 18 79183 . Spring 2016 Replace rear brake rotors, parking brake drums and all pads. Install 4 shock absorbers, align front end. Install appropriate towing equipment. Blue Ox base plate, Blue Ox Avail tow bar, M amp;G engineering toad air braking with breakaway kit, Hopkins brake wiring kit. Hood and 4 fenders repainted after the 2016 Alaska trip.
7 24 17 73,855 miles tires replaced at Discount Tire in Salem OR with OEM tire. Bridgestone 255 70 18 Dueler AT RHS. Same as OEM which got 73,855 and still had a few thousand miles left but I replaced due to good cost and no tax in OR. Tires currently have 10 11/32nds tread depth. Original tread depth 14/32nds.
Jeep gets 20 22 mpg in typical driving, has the stated miles driving and approximately 27000 towed miles
Current odometer reading 146105 km, 90,585 miles. Towed mileages based on trip logs kept for each motorhome trip. We used the Jeep as our toad and were able to explore off road areas. We did NOT do extreme off roading just out of the way wilderness trails we found. I wasn t about to break the Jeep just to see what was over the next hill. Jeep drives well, comfortable, tows like a breeze, reliable. Selling since I won t be driving a motorhome or towing anymore.
Asking 20,000 USD and includes all towing equipment including the Tow Car Shield front end cover. That custom fitting front end cover goes over the entire front end, hood grill, fenders, and windshield to provide maximum protection when towing. The cover is just laid on the hood and not secured. When properly attached it s tight and does not flap. Felt inside material doesn t scratch paint. A MUST if driving to Alaska. Jeep kept garaged and towing equipment attached to motorhome kept under pole barn except when in use. Alabama Roll Tide spare tire cover is NOT included.
NOTE the Jeep is located in south Alabama, Hartford AL, not Birmingham, but the classified menu won't accept that.
View this ad at Forest River Classifieds - 2012 Jeep Wrangler Sahara
