Mister B
Advanced Member
Stealership said that the brackets came in and have installed them. Took a week for brackets to come in from FR. Pickup on monday (having other maint. and annual inspections done along with recall)
Rosko said:A simple solution to brackets without cracks, use a Heavy duty C clap to press upper support arm and under side of propane tank plate bracket. This takes the weight off L brackets that are in question. Lowe’s sells them at $11 apiece.
To the admins: I am duplicating this post in the FR3 section because this is a critical issue and I believe it belongs in both Owner sections. Your call, of course.
Potential Number of Units Affected 6,966
Summary
Forest River, Inc. (Forest River) is recalling certain 2019-2024 Georgetown and FR3 Class A motorhomes. The liquid petroleum gas (LPG) tank mounting brackets may break, which can result in the LPG tank becoming dislodged and damaged.
Recall notice link: https://static.nhtsa.gov/odi/rcl/2024/RCLRPT-24V103-7106.PDF
There's not too much information on the actual repair process yet. While MORryde knows what they did to add reinforcement to new coaches, someone has to develop, test, and document the process to retrofit the reinforcements to all of the variations of existing motorhomes. That is not a process that can be rushed.
Note that dealers will NOT be notified until March 24, 2024 so your dealer will NOT have any idea what to do for a repair until then.
If you want to discuss this with your dealer you could email them the PDF I attached to this post. It has several pictures of actual failures people have experienced.
Remember, the number of reported failures is currently in the single-digits, like one-tenth of one percent so far. I'm sure that number will increase but this likely is a "Low probability-High impact" condition.
Note that the NHTSA and Forest River acted off of people who filed complaints with the NHTSA and Forest River. No one with a Georgetown or FR3 manufactured prior to March 2019 filed a complaint.
Does that mean none of the earlier ones are potentially affected? It is unlikely that the very first person to experience a problem really was the first person to have the condition AND reported it to the NHTSA.
Me, I'd be looking at the pics in this PDF and checking mine even if it is outside of the recall range. This is something an owner can do. You MUST clean the brackets and area and examine the brackets from the top and bottom using a bright flashlight. If you find a problem please file an NHTSA complaint. The recall can be expanded if necessary.
Thanks to everyone who filed an NHTSA complaint about their failures. Your action is helping to keep other Georgetown families safe.
You'll note that MORryde decided to improve the tank mounting as of December 11, 2023. That means FR definitely took this issue very seriously.
And especially thanks to Forest River for taking care of this issue despite the cost to FR.
tourwdw said:Just brought mine in for other warranty work and they checked on this while it was there. Dealer took pictures and sent to Forest River who deemed a fix was not needed on my rig.
Twinboat said:After 20 minutes of paper shuffling and phone calls, I was told I'm good, no recall for me.
