2019 Cherokee Grey Wolf 25rl Outlet Issue
DannyBoi
Oct 1, 2013
4
Morgan County, Tn
So I've read about 250 threads about outlets and GFCI outlets on this forum before realizing that I was going to have to find something specific to my camper if I was going to get anywhere. Anyone who has a 25rl, the interior outlet by the dinette and the exterior outlet do not work. Both of them say GFCI protected outlet, but neither of them has a reset, and its the only 2 that aren't working. What am I missing?
Have you located any GFCI outlets in your rig? Usually the GFCI will protect the outlets downstream. GFCI outlets are usually located in the bathroom and occasionally in the kitchen. There is also a general one in the power panel.
Welcome to the forum!
Moved thread from the Tech and Repair section to the Cherokee sub-forum since the OP is asking for others that own the same model(Anyone who has a 25rl, the interior outlet by the dinette and the exterior outlet do not work.).
I start these searches with the closest dead outlet to the breaker box. they are daisy chained from outlet to outlet going from the breaker box out.
I open the last dead outlet to see if there is power at the incoming wire and if not trace that incoming wire to its next junction. Good Luck DR
Yes the only GFCI I can locate is in the bathroom. And that outlet only concerns itself and the ones along the kitchen and back wall.
If you have power coming off each breaker, take each outlet out of the wall till you find the one that has a dead wire. Its only two screws each outlet. You will probably find a loose connection. DR
