For Sale: 2022 Forest River Rockwood 1910 ESP Extreme Sport Edition - Colorado
UT_Vol
Oct 28, 2024
12
This Rockwood tent camper is in great shape and a wonderful floorplan! It comes outfitted with the Extreme Sport Package that raises the ground clearance and includes a 200W solar panel along with 1000W inverter onboard. These allow you to reach remote camping spots that most larger campers can't reach and be able to have most of the comforts of home when you are there.
This trailer has been well cared for and garage kept for the majority of its life unless it was out camping. I have went around and resealed the silicone seams as is recommended each year. I have also just winterized the lines. We recently had an incident with a squirrel that went rouge a the campground causing me to make some minor screen repairs. We have added PopUp Gizmos to the camper to improve its ability to camp in the early spring and late fall. We also added reflective window inserts to help keep out the heat in the summer and keep the heat in during the colder times.
The front bed is 60"x80" allowing plenty of sleeping room. The second bed is 48"x80" again plenty of room for the kiddos or other campers. Both beds have internal mattress heaters and a 12V fan for circulation of air. We also added foam insulation layer under each bed area. There is a nice 3 burner range that has a cover and a small sink. This coach is equipped with an overhead kitchen cabinet and storage nets over both bunks. LED lights throughout the coach provide more than ample lighting There are plenty of USB ports for charging any items that you may need charged.
Outside you will find a portable griddle and small shelf that come in really handy. The EZ Reach Storage Trunk makes plenty of room for all the items you need to take with you. There is a Hot/Cold Spray port on the side of the unit that makes for easy outdoor cleaning times or shower time. There are 2 20lbs Propane tanks with an automatic switch over for those times one runs out. The battery box in the front is plenty big enough to house the batteries for your adventures while boon docking. However if you want to plug up to campsite or generator there is a 30 Amp service plug for your shore power needs. Along with connection points for TV outlet and Water hookups.
  • Maximum Sleeping Capacity 6
  • Length 20 ft 4 in
  • Length closed 17 ft 6 in
  • Height closed 5 ft 11 in
  • Base Weight 2180 lbs
  • Carrying Capacity 724 lbs
  • Hitch Weight 254 lbs
  • Single Axle
  • Heater 20,000 BTUs
  • Fresh Water Capacity 20 gal
  • Water Heater Tank 6 gal
  • Wired and Has Bracing for Roof mounted Air Conditioning
  • 3 Burner Range w/Cover
  • Wood plank vinyl flooring throughout
  • Compact Refrigerator Electric or Propane
  • Radio with interior and exterior speakers
  • WiFi Ranger
  • 12 Volt Electric Water Pump
  • Residential Style Cabinet Doors
  • Full Extension Metal Drawer Guides
  • LED Ceiling Lights
  • 1000W Inverter
  • Window Curtains w/ Valances
  • Storage Net Over Bunks
  • Vinolon Supreme Tent
  • Smoked Vinyl Windows
  • Overhead Kitchen Cabinet
  • Vinyl seating material for easy cleaning
  • Dinette that converts to a 3rd sleeping area
  • Exterior Spray Port
  • Double 20 lbs Propane Bottles
  • Large Entry Grab Handle
  • 35 Amp power Converter
  • 30 Amp Shore Power Hookup
  • Thule 8 ft 6 in Awning
  • Double Step with support legs
  • 200 W Solar Panel mounted on roof
  • Patio Light
  • Outside Recep
  • Double Batter Box
  • EZ Reach Storage Trunk
  • Electric Brakes
  • 15" Alloy Wheels w/ Mud Rover Tires
  • 4 Stabilizer Jacks
  • EZ Lube Axles
  • Black Diamond Plate
  • Antifreeze Inlet Bypass
  • Rear Mounted Full size Spare
  • Takes a 2 in ball
View this ad at Forest River Classifieds - 2022 Forest River Rockwood 1910 ESP Extreme Sport Edition -...
