For sale 2024 Dynamax Isata 3 24FWSFX - 1 Owner / <4500 Miles / 6-Months Factory Warranty
$145,000.00
or best offer
Year
2024
Make (Brand)
Dynamax
Model
Isata 3
Trim
24FWSFX
Length
25
State/Territory
FL
Nearest City
Cape Coral
Details
2024 Dynamax Isata 3 24FWSFX Freedom Edition. Purchased new in May 2024 and currently less than 4500 miles.
We downsized from a Super C and after a few trips we have decided we miss the space of the Super C. There is Factory Warranty remaining until May 15, 2025.
The pictures are from the dealer website when I bought it and the coach still looks as good as the day we drove it off the lot.
This is the All Electric Freedom Edition with 600Ah of Lithium Batteries, 590W of Solar and a 3000W Inverter that can run the A/C, Induction Stove or Convection / Microwave Oven.
It also has the Truma Combi Furnace and Water Heater that uses diesel from the fuel tank or shore power so no propane is needed! The 12V compressor refrigerator cools down quickly and will run days off the batteries.This motorhome is built on a 2022 Mercedes Benz Sprinter 3500XL Chassis and is the last year the V6 Turbo Diesel. It also has a 7-speed transmission for 12 - 15MPG. It can also tow up to 4500lbs and no problems towing a 4-door Jeep Wrangler.
The Sprinter handles and rides better than any motorhome I have previously driven and is very easy to maneuver. At only 25 feet long you don't have to pull a vehicle as you can sightsee or grocery shop from the coach. We typically only travel with our eBikes.
I have added several thousand dollars in upgrades including the following:
- MIdCity Engineering Remote Start / High Idle / Alarm / Drone Mobile System - This system will allow the engine to be high idles to charge the batteries without damaging the engine or emissions systems since diesel engines should not be idled below 1000RPM's for more than a few minutes. You can also use it to remotely lock and unlock doors as well as start or stop the engine.
- Progressive Industries Hardwired 30A EMS and Surge Protector
- Dometic 310 Porcelain Toilet
- Rear Sumo Springs
- Roadmaster Spare Tire Carrier and New Spare Tire
- Onboard NOCO Chassis Battery Maintainer
- Battery Compartment Powered Ventilation System
- Starlink Outside RJ45 Jack
- Fresh Water Tank Drain Electronic Valve w/ Remote Control
- Additional Bathroom Towel Storage Racks
- Kitchen Paper Towel Holder
- Water Pump ON / OFF Switch added in Bathroom
- Agile Offroad Sprinter Horn Upgrade
- Agile Offroad Sprinter Hood Struts Upgrade
- Unlimited T-Mobile 4G HotSpot Data Plan Until September 2025
This motorhome is as good as new with several features you won't find anywhere else. Just load it up and go!
Message for more information.
