Yes does anyone have this issue on the 2024 ShastaIs there a question in here?
Mentioning which specific Shasta model you have might help as well.Yes does anyone have this issue on the 2024 Shasta
The black water tank is installed with the shallow end under the bowl pipe.
The clearance of the bowl pipe is 1/2 inch from the bottom of the black water tank.
Compact 16 RE ShastaMentioning which specific Shasta model you have might help as well.
Not that I've seen yet. You could do a search in the Shasta sub-forum, to find other 16RE owners.Are there any Shasta 16 RE 2024 owners on here?
Thanks, but that would void any warranty going forward.This would be a warrantee issue, but if it was me, I would probably pull the waste pipe out and cut off the extra and re install it. But I worked for years as a plumber. Good Luck DR
How could shortening the input pipe from the toilet into the black tank have any effect on the deep end emptying?Thanks, but that would void any warranty going forward.
I don't know if the deep end would empty completely.
The deep end is opposite the dump valve, the black water would have to flow up to the shallow end and out.How could shortening the input pipe from the toilet into the black tank have any effect on the deep end emptying?
Your original post says the INPUT pipe from the toilet is into the shallow end. Now you’re saying the OUTPUT/dump pipe is in the shallow end.The deep end is opposite the dump valve, the black water would have to flow up to the shallow end and out.
The waste would have run up into shallow end form the deep end in order to dump.How could shortening the input pipe from the toilet into the black tank have any effect on the deep end emptying?
Please read what I wrote in post #16.The waste would have run up into shallow end form the deep end in order to dump.
The waste would have to run up into the shallow end form the deep end in order to dump.
