Moved thread from the Tech and Repair section to the TT/5th Wheel section's Cherokee sub-forum since the OP is asking for model-specific information on a Cherokee product.Does anyone know what the battery wire gauge is on a 2024 wolf pup, trying to calculate which fuse i would need for an lifepo4 battery upgrade?
Keep in mind that the fuse is there to protect the wire. I think #8AWG will get pretty hot before blowing a 150A fuse. I like MBRF on the post, that's what I have on the three of mine.what i am doing is getting a Eco Worthy, blue tooth,12v 150ah lifepo4 with a 120amp bms, the cheaper batteries sometimes dont have the most reliable overcurrent protection, i just want to put a MRBF fuse on its positive terminal to protect the wiring between it and anything else i might add in the future. So far it appears i would need about a 125 to 150 amp version.
Sounds right, so 125a would be betterKeep in mind that the fuse is there to protect the wire. I think #8AWG will get pretty hot before blowing a 150A fuse. I like MBRF on the post, that's what I have on the three of mine.
NOSounds right, so 125a would be better
