Campsite Ultra 2025
Morning all. So we recently purchased a brand new 2025 and want to see what we need for upgrading/adding to the current solar setup that it has. It has a Rich Solar 100 watt panel and controller (RS-PWM30P). The battery is a lead acid deep cycle. I'll get the specs from it this afternoon. I want to add my Renogy panels that I removed from the old trailer. They are 200 watts each. My thinking is to install them at the front and run the cables to the rear. The MC4 connectors are right at the inlet box so plugging in the 3 panels with the Y adapters should be fairly easy. I emailed Forest River for the roof framing diagram and to ask what gauge wire was ran. It looks like 12 gauge. Its aluminum framing so it shouldn't be an issue securing the panels. I'm still learning the solar setup but I don't have any problem with upgrading to an MPPT controller if needed. I appreciate any help and links (controllers, lithium batteries, etc) that you can provide. I'm pretty sure that running 500 watts of solar with the current battery is not a good idea LOL.
My dumbed down version to sum it up:
Currently has a 100 watt panel and 30 Amp controller.
I believe its a 12 gauge wire setup currently.
Want to add additional 400 watts by adding 2 each Renogy 200 watt panels
Do I need a different controller?
Do I need a different battery? Do I need 2?
