2025 FR3 33Z Inverter
BERNARD Perkins
RV LIFE Pro
Feb 12, 2025
2
Does any know how much of the coach runs of the 2000 watt inverter on a 2025 FR3 33Z?
(ie: Microwave, TVs, ACs All 110 outlets)
TVs, some outlets, residential fridge, and maybe microwave.
30 amp hookup is 3600 watts, 50 amp hookup is 12,000 watts. You'll need at least 30 amp to run an AC.
Moved thread from the General Community Discussion section to the Motorhome section's FR3 sub-forum for better help from other FR3 owners and possible factory support. Also because the OP's questions are not general community questions.
That may be an interesting question to pose directly to the manufacturer. Along with:
1) How long can that inverter run off fully charged batteries if all of its 2K watts are being consumed.
2) How much inverter capacity remains after powering the fridge and TVs?
biggest thing is working out what is wired to run on inverter
sometimes only some stuff can be used while other times everything can be used
BUT ... not all at once
disconnect shore power and turn on the inverter
TEST what stuff works in your setup.... turn it on / off .......... one at a time
just don't leave stuff on as you only have 2000w available
you will soon learn that making a K cup and heating up a Poptart in the microwave won't happen at the same time
Your dealer should be able to answer that question. That model is probably too new for it to have owners on this forum who know the specs. Plus models do vary from the specs.
That's a new FR3 PLUS and it's details are impressive for power.
  • 6.0KW NPS Yamaha Generator w/PureSine Inverter Technology (Manual/Keyless Start)
  • Go Power Solar Controller w/200W Solar Hard Panels
  • (2) 100 Amp Battle Born Lithium batteries
  • 2,000 Watt Xantrex inverter
Welcome to the forum!
2025 33Z inverter will work ALL 110 outlets and Microwave
Your TV's, refrigerator, and power theater seats are 12 volt. Hope this helps
