Yoods
Advanced Member
RV LIFE Pro
I was exploring what features a 2025 A213HW might have and learned the HW model will be no more and will now be A213HS.
Looks like the A213HS has a bigger fridge, stove has been moved, no microwave, 1,000 more heat pump BTU's, no electric lift, and 25 amp converter (down from a 35 amp ?).
From images don't see radio, speakers or external antenna, porch/exterior door light, or wi-fi extender. As a plus you can add ProRac Permanent Crossbars (150lb rating) to mount bikes or water craft.
Very curious about lack of microwave, and if it really does just have a 25 amp convertor, and why.
The outside of the fridge looks bigger but not sure of size or if it has a freezer. The specs only say 12V Refrigerator w/ 100W Roof Solar Panel. I wonder if the 100 watts solar can keep the fridge cool while moving.
I wonder what type of solar controller it has; PWM or MPPT. I also wonder if you can you expand the solar on the roof to say 200 watts (if it is internally wired through the roof panel in a manner so you could change from a 100 watt to 200 watt panel with minimal issues, for example).
If anyone has any insights on these changes and/or my questions I would be curious to learn what you know.
New A213HS: https://forestriverinc.com/rvs/rockwood-hard-side-pop-up-campers/A213HS/9627
Catalog for 2025 Rockwood Hardside Campers: https://forestriverinc.com/rvs/rockwood-hard-side-pop-up-campers
