May 17, 2025 #1 FI Fishspike Senior Member Joined Jul 7, 2016 Posts 217 Having trouble finding the main filter. The one in the back bedroom under the closet. Ant help would be appreciated
May 17, 2025 #2 RX rxgac Advanced Member RV LIFE Pro Joined Mar 3, 2019 Posts 85 What year? They eliminated it in our 23. May have been the first year or maybe 22.
May 17, 2025 #3 OP OP FI Fishspike Senior Member Joined Jul 7, 2016 Posts 217 Guess that would help. 2022. Thanks
May 17, 2025 #4 RX rxgac Advanced Member RV LIFE Pro Joined Mar 3, 2019 Posts 85 Id guess if its not in the cab with the pump, then there isnt one.
May 17, 2025 #5 RE Rekab Advanced Member RV LIFE Pro Joined Nov 6, 2020 Posts 45 Location WA It does not have an in line filter. You have to use the filters that are outside of the trailer. Mine is a 2023. Same thing.
May 17, 2025 #6 RX rxgac Advanced Member RV LIFE Pro Joined Mar 3, 2019 Posts 85 I set up two 10” filters outside. One a sediment and the secona a carbon. Use the replaceable filters that are pretty cheap.
May 19, 2025 #7 MR MrPukaShell Senior Member Joined Feb 24, 2021 Posts 836 Location Simi Valley CA Look under the bathroom sink
May 19, 2025 #8 OP OP FI Fishspike Senior Member Joined Jul 7, 2016 Posts 217 I apologize I found the filter assembly. Trying to locate the filter cartridge to replace it
May 19, 2025 #9 RX rxgac Advanced Member RV LIFE Pro Joined Mar 3, 2019 Posts 85 Just curious, where was it?
May 19, 2025 #10 OP OP FI Fishspike Senior Member Joined Jul 7, 2016 Posts 217 It’s on the right side in the bedroom under the closet. It has its own door just inside where the fresh water connects on the in side.
May 20, 2025 #11 OP OP FI Fishspike Senior Member Joined Jul 7, 2016 Posts 217 This might help. I need the filter. I think they are pretty standard. Thanks everyone Attachments IMG_3593.jpeg 130.1 KB · Views: 13 IMG_3592.jpeg 111.6 KB · Views: 13
May 20, 2025 #12 RS RStormC Senior Member Joined Jul 29, 2011 Posts 113 Location Ogdensburg NY Walmart
May 29, 2025 #13 Ex-tenter Casual Camper Joined Jan 25, 2021 Posts 283 Fishspike said: This might help. I need the filter. I think they are pretty standard. Thanks everyone Click to expand... They are not. I bought one for my 2608BS only to find it's the wrong size. Make sure you get the right one.
