Took the RV for a 3000-mile trip over an extended 4th of July holiday. Everything worked well, but noticed a significant amount of front tire wear, but only the outer rib. the inner most rib is wearing as well, but not as bad. checked/double checked/triple checked/etc the pressures throughout the trip with a gauge and they are at the recommended 95 psi cold.
tried searching and did come across this post
https://www.forestriverforums.com/f...senger-side-tire-wear-240700.html#post2640767 indicating excessive wear, but that was the only thing that came up.
I assume others have had the same experience. Was the fix an alignment?
