Willhound
- Joined
- Apr 26, 2023
- Posts
- 1,010
Our Cherokee 39RL is on a permanent site and will never move unless a tree falls on it and I have to drag it out for a new one.
The factory installed rain gutters have never been good, kind of poorly installed and a low point on both sides, right at the joint for the gutters so water runs down the sides of the trailer. I've worked on them several times over the last 2 seasons and am tired of fighting with them. I snowshoed into the camp yesterday and found that snow melt was dripping down on top of the kitchen slide, running down the side and finding a way in next to the fridge. Not a huge amount and I wiped it up and left a fan running. Got out the Gorilla tape and step ladder and ran a strip of tape across the top of the slide to re-route the water. Seems to be working. My plan in the spring is to run residential eavestrough down both sides with proper downpipes to direct water away. I plan on running a strip of butyl tape that will help hold the eavestrough, seal it against the side of the trailer and act as a seal for the 1" stainless steel screws with fender washers that I'll mount about every 3 feet to attach the eavestrough. The typical hangers leave the eavestrough too far out from the unit so don't work.
Any one ever do anything similar? Pros/Cons? Yes, I realize I'm putting a bunch of screw holes into my siding but they'll be properly sealed for water intrusion.
