Details of the Installation Process
• Make a simple workbench out of sawhorses and a piece of plywood laid on top. This gives you a clean work surface off the ground on which you can work with the H assemblies.
• We started with the slide closed and removed as many screws on the gear rack as we could access on the slide side-wall, leaving the very end screws in place to hold the gear racks in place on the slide wall. We only worked on one end of the slide, leaving the other untouched.
• We placed an 8” (approx) stop board on top of the slide to restrict the slide from tipping out, if we made a mistake in the repair process.
• We opened the slide to rest against the stop board. Since the slide was stalling on us, we needed to enact the over-ride feature of the “Dual Motor Synchronous Velocity Slide Controller” that is shown on Page 4 of the Repair Kit Manual. Other manuals discuss this item in greater detail, and we have version C2 of this Controller. The Controller on our Coach is located in the roof of the Main Storage Bay (the one with the sliding tray). Other locations are possible, and there is one for each Schwintek slide. There is an opening and on the right side is a microswitch that you press 6 times and then hold the 7th time until a bunch of lights start flashing. This puts the Controller in override mode for the next 60 seconds. That means that it will ignore any feedback from the motor that says the slide is jammed. This allowed us to open the slide with the standard switch inside the Coach.
• Outside the Coach, we jacked up the end of the slide to remove the weight from the roller nearest to the slide end that is being repaired. Just raise it enough to take the weight off the roller. You want to leave no vertical load, up or down, on the H-column.
• Remove all the remaining screws holding the gear racks to the sidewall of the slide, including the screws that you left attached inside the coach.
• Slide off the rubber bulb seal on the H-column to expose the screws that hold the H-column to the Coach body. These bulb seals prevent drafts when the slide is closed and they slide down on a track for removal.
• Remove all the exposed screws from the H-column. There is one in a slightly different position at the top, under a rubber bulb seal. This holds the motor in place.
• Place some duct tape alongside the Gear Rack and the H-column in such a way that you avoid scratching the paint when you insert a scraper under those parts to separate them from the walls. Loosen the Gear Rack and H-column from the walls.
• Inside the Coach, remove any optional black plate that may have been installed on the Coach wall parallel to the H-column. You should also remove the vertical rubber bulb molding that is attached to the H-column–these moldings seal the slide from drafts when it is open and they are on a track, so they slide up or down.. You can optionally remove the sweep moldings that are attached to the H-column – these are inside the coach and sweep against the slide wall as it moves.
• Inside the Coach, disconnect the motor wires from the motor on the good end of the slide. The motor is at the top of the H-column inside and you might have to strip back some molding to see it. This motor has 300:1 or 500:1 gearing, so leaving the motor in place but disconnected will prevent that end of the slide from moving or tipping when you work on the end that you are repairing.
• Briefly run the slide control switch in the direction to move the slide In. This should release the H-column from the Coach wall. Note that Schwintek provides some kludgy instructions to run a jumper wire to that motor and power it from a cordless drill battery. Our procedure uses the motor controller and Coach batteries to the same effect, but in a more professional manner. Recall that we disconnected the motor from the good end of the slide, so this process only runs the motor on the end of the slide being repaired.
• Disconnect the wires to the motor on the end of the slide to be repaired.
• Remove the motor (perhaps not necessary at this point) from the inside of the H-column. To do this, remove the short screw on the outside of the coach from the H-column that goes into the motor. It may still be covered by a seal, but, at the very least, it was covered by the bulb seal that you removed. The motor comes out by lifting it up and pulling it inside the Coach through the notch in the H-column. You may need a screwdriver to push it up.
• At this point, you can remove the H-assembly from the outside of the Coach. There is enough space between the Coach wall and the Slide wall to angle the assembly out and clear any flanges on the outside face of the Slide wall.
• Put the old H-assembly on your makeshift workbench and examine it for damage, and to see how the parts are assembled. In the previous post, I’ve attached pictures of the damaged V-rollers and bearing blocks from my slide.
• Insert the new upper and lower gear racks into their respective bearing blocks. You need to make sure that they each contact their spur gears at the same time, so that they extend from the H-column by the same amount. Lippert calls this synchronization a timing procedure. When done properly, moving one rack in and out moves the other synchronously, without jamming or binding. When doing this, note that the gear racks have a machined notch on one end and this is the correct reference point for synchronization. The other end may have been cut to length with a hacksaw and is not a reliable reference point.
• Trim away any rubber gaskets that may get caught in the assembly and jam the gears or shoe from moving.
• In some of its documentation, Lippert suggests that the mechanism shouldn’t be lubricated. But, in other places, such as on Page 9 the Repair Manual linked above, it recommends using CRC Power Lube with PTFE (misspelt PFTE by Lippert). Elsewhere it says this is the only acceptable lubricant, so I made sure I got it. The PTFE is generic Teflon and will leave a dry lubricant. But, it is in a petroleum based aerosol. Using substitutes may have an aerosol that damages the plastics or rubber in the assembly, so I protected my $1400 investment with their recommended lubricant.
• I used this CRC Power Lube on the V-rollers, gears, Gibs and the shoes, as well as the gear rack grooves in which the shoes slide.
• Lippert had some foam rubber ends for the shoes, which I was worried could jam in the grooves as the shoes slid back and forth. Moreover, the Powerlube dissolved the glue holding them on, so I discarded them. It might be that this foam rubber is intended to sweep the rack groove clean. A better solution would be to periodically inspect the groove and clean it with a Q-tip.
• Next, we installed the new H-assembly into its place between the Slide and the Coach. At this point, the motor is not installed so that the racks can move back and forth.
• Screw the upper and lower gear racks to the Slide wall, using the holes from the original gear racks. They have identical spacing and we had checked to make sure that the original gear racks were parallel.
• Push the H-column into place against the coach wall. We had to file off the bottom end to get a fit.
• Lower the jack that was holding the slide so that the weight is borne by the roller on the aluminum plate under the slide.
• Since the aluminum plates raise the H-column by 1/8”, you want to consider drilling new holes to hold the H-column to the coach. You can’t just enlarge the existing holes. Fortunately, the holes provided in the new H-column are about 1/2” above or below the holes on the original H-column. So, you need to drill new holes to start the self-tapping screws. In my original installation, the installers broke several self-tapping screws on this assembly, and I decided to be more careful than them.
• With the H-assembly installed, we found that the slide moved out easily by hand, so we knew that there was noting binding elsewhere in the slide system.
• We dropped the motor into place from the inside of the Coach on the repair end.
• We hooked up both motors and removed the 8” block at the inside top of the slide.
• We hit the switch to move the Slide in and out, synchronizing the position of both ends.
• If the above works, install the bulb seals and inner flanges and you are done.
If that doesn’t work, read my next post!
