Oct 26, 2020 #1 WD wdweldon Senior Member Joined Jun 21, 2016 Posts 275 IS there somewhere to obtain tire air on a diesel or do I need to purchase a external compressor?
Oct 26, 2020 #2 NO3putt Berkshire 390QS Joined Feb 5, 2011 Posts 1,489 Location Colorado In the generator area, right side above the generator you should find a air connection point. I put an off/on valve and an quick connect for my air hose. A bit slow but will air up my tires.
Oct 28, 2020 #3 Lincman983 Senior Member Industry Pro Joined Nov 6, 2019 Posts 870 Location Lakeville, IN WD, if the air port is not in the generator rea it should be in the first run bay under the driver area should have a valve with a quick connect.
Oct 28, 2020 #4 OP OP WD wdweldon Senior Member Joined Jun 21, 2016 Posts 275 Great, I will check it!
