Alco Torsion Axle mounts sheared off!
RONSTAR911
Advanced Member
Apr 25, 2011
68
Delta BC
My Camping season ended yesterday when my 2009 Palomino Banshee Tent trailers axlel tore away from the frame and jammed my wheels into the fender wells, I had to get it towed home on a flat deck a hundred miles back to home. I found one other thread on here about the mounts cracking but I guess mine went all the way. Im assuming I will have to replace the entire axle, but wonder how this happened? If I was overloaded (probably the case) can i put the next size one in so this does not happen again. Its a single 3500 pound Alco Torsion setup with 15" "offroad" tire and ride height. here are some pictures. let me know what you guys think. :crying:
1. is this a known weak point on these axels?
2. do you think the manufacturer will do anything for me?
3. where is the cheapest place to find replacement axles?
Thanks everyone
Ron Y
Delta B.C.
Thanks everyone
Ron Y
Delta B.C.
Never heard of it before, but looks like the bolts were not torqued.
Yes I wondered about that myself judging by the way it pulled out like that. I pulled out the alco owners manual and sure enough it says every 6000 miles/ 6 months these bolts should be checked and retourqued to spec. WHO KNEW THAT? I doubt the thousands of people who own these axels on their trailer know they should be checking the mounting bolts! . That even makes me more frustrated because Im mister preventative maintance when it comes to my trailer, knowing it may have been prevented by me checking them once in a while makes me sick.
Wow that's weird how that tore away !
With the bolts not being torqued, the shock load of the torsion axle transmitted to the mounts will accelerate the metal fatigue. Once it gets to approx. 0.015" to 0.030" clearance, it accelerates much faster and when it gets to 0.25", all hell breaks loose.
Excuse me. The bolts are intact, the top photo shows the metal ripped around the, and the lower photo shows the metal tearing at the weakest point, the bend. Look how far the centerline of the axle/wheel is from the point of movement in the tube with the rubber springs are located. The wheel had a lot of leverage and the weakest points failed.
I was under my RV last week and I see things that have me scratching my head.
Both photos show where the axle was shifting (shined metal around the washers) and the top picture shows where it tore around the hole and twisted.
Well, I'm pretty sure that the design is flawed. There should be a heavier bracket or extended farther to offset the pivot point as the other gentleman pointed out the swing arm is very far back compared to the location of the bracket. Either way I have to fix it And prevent it from happening again. I'm considering upping to the 4000 pound model although it still uses the same bracket setup.
Beg to differ on the design flaw and a heavier bracket, too many out there without your problem. Maybe heavier gauge hardened washers. The lack of torque on the bolt is the culprit. Should it have come loose, no, but maybe a larger gr 8 bolt, hardened washers & nuts would have prevented it. But, bottom line, being loose caused the problem.
Al-co manual :see page 31 for torque specs
Alco manual.
  • ALKO_2kto7k_OM.pdf
Did you ever check the torque on the bolts? If the nuts or bolts were eating into the washers, they should have been replaced with hardened washers. They are no doubt gr8 bolts from the torque values. The factory may not have used hardened washers which is a no-no when using any gr8 hardware from a design standpoint.
No I never did check the torque, I agree that the bolts came loose and then it was all a matter of time. One point you make is interesting, on the side that pulled out the washer is bent over the nut indicating it was NOT Gr8 hardware. It will be interesting to see how many people when they check theirs find or not find issues or cracks/loose nuts.
They are using stop nuts or locking nut which ever you prefer to call them. Those are a one time use component. They can not be torque do to the fact of resistance from the nut nor should they come loose. I disagree with re-torquing without changing out nut.
You are correct, hardened washers do not bend, they break. As I stated before, when a knowledgeable engineer specifies gr8 bolts, nuts and hardened washers on 1018 steel or the material being clamped is heat treated (hardened) and doesn't require the hardened washers.
No doubt the assembler either grabbed soft washers or someone didn't specify hardened washers, either way, bad mistake.
Grade 8 Hardware
Also interesting point Fkent, I have installed many trailer hitches over the years and they ALWAYS use Gr8 Hrdware and a Gr8 Lockwasher and Nut. NOT a NYlock for that same reason. I will definitly be replacing all that hardware when I repair it. Thanks for the input.
Gr8 lock nuts can be used more than once. Read SAE J429 spec on locknuts.
Federal Aviation Administration Advisory Circular allows nuts to be reused if the prevailing torque is within specification.
Just looked under mine at the ALCO axle mounts - no need to retorque the bolt, the brackets WELDED to the frame????? Now I guess I'll have to crawl under it after EVERY TOW and inspect the welds, with the way welds seem to be failing on TT's. Oh well.
Being the paranoid person I am, I would still replace the soft washers with hardened ones and re-torque the bolts.
