The alternator's voltage regulator won't supply enough volts to effectively charge a depleted trailer battery other than in an inordinate amount of time as it's only designed to put back the few amp hours the starting battery used. The long relatively thin wire back to the trailer doesn't help either. After a few minutes I only see a couple amps flowing back to my trailer. Voltage regulator stabilized about 13.7vDC and it's less at the trailer battery.
Better than nothing.
Running an auxiliary alternator to charge the house batteries is common on mid size boats and emergency vehicles.
-- Chuck
I never put an ammeter on line, but I did measure voltages when my first A-frame fridge had to be run in DC mode while towing. My Hyundai (re-badged Kia) minivan would start out at about 13.7V with fridge off. Fridge on (10 amp draw) would drop to 13.1V. Trailer running lights added another 6 amp draw and decreased voltage to 12.8V until I switched them out to LED "bulbs".I've seen claims of 30 AMPs, that's the usual fusing on the TV. Then other places it's called a trickle charge. I'd like to quantify it better. Not that hard to put an amp meter inline from the 7 pin cable on the trailer.
Mike, I would love to see more info on how you set that up, i.e., Where did you mount the charger, how did you wire it, etc. Is this the charger you used?The advent of DC-DC Chargers has really improved the capability of the tow vehicle to charge trailer batteries. Even with the existing wiring. As long as the voltage on the charge wire at the 7-pin connector doesn't drop below 8 volts the DC-DC chargers will put a surprising amount of power into a trailer battery.
Also not terribly expensive with a 20 amp Renogy unit costing $127.
The voltage regulator in even Chevy trucks regulates the voltage, not the amperage -- otherwise it'd be called an amperage regulator.![]()
When the voltage regulator senses the truck batteries are charged it lowers the output voltage. Good battery chargers work the same way -- by regulating the voltage. They start out about 14.7vDC and drop as battery voltage increases.
It's all related, of course. The higher the alternator voltage the more current will flow to the battery. The voltage regulator keeps this voltage relatively low, typically 13.7 after a few minutes, to keep from overcharging the vehicle battery. The voltage at the end of the wires to the trailer battery will be lower. Correct?
This voltage differential effect works if you connect two batteries in parallel. The battery with the lower voltage will constantly siphon power from the stronger -- and one is always stronger. After a while both batteries are dead.
-- Chuck
https://www.amazon.com/Renogy-Battery-Batteries-Multi-stage-Charging/dp/B07Q5VYPCF
-- Chuck
Fred mentioned Processor-Controlled Alternators. This is where it really pays to Read The Fine Manual! On our GMC Sierra 2500, the manual states (under towing) that if you want to put a higher voltage on the +12 line of the 7-pin connector while driving, turn on the headlights.
Find out if your vehicle does the same thing.
Well, I have two degrees in Electrical Engineering and I have no problem with your explanation. You are taking the load-side view instead of the source-side view. That's not uncommon.It's helpful for me to think of the battery drawing or sucking power from the alternator (or whatever is charging it) rather than the alternator pushing it. Is sucks harder when the voltage differential is high and barely at all when there's less than a volt difference. (I'm sure the electrical engineers cringe at this explanation!) Automobile voltage regulators typically run at 13.7vDC and battery fully charged is 12.7vDC. Voltage will be less at the trailer connector because of the wire and distance.
You're right. The power has to come from somewhere, or as us EEs say, the power is constant. Power = volts times amps, with a little efficiency loss.I've no experience with a DC-to-DC charger but am reminded there's no free lunch. The power has to come from the charging source.
