lvnlife1973
So, I have this outdoor Directv satellite dish that I was successful at connecting from outside using the cable output. Had to undo the connection when I upgraded the MH (2014 Georgetown 328T) TV antenna to a Jack Antenna.
I had found a thread here previously that I followed but darn if I can find it again.
Anyhow, this is what I've done:
1. Attached satellite dish to cable input on the "outside" of MH (mine is where the electrical stuff is, I guess people call it the garage?)
2. Took cable wire on back of A/B switch and connected it to the back of SD settop Directv box where it says Satellite In)
3. Cable wire from Out to TV goes into the back of the A/B switch box that says Cable.
4. Switch on A/B box is set to Cable.
TV is on and set to channel 4 and Channel Input is Cable. I have the dish box on and you see the Directv screen on the TV and then it's off to trying to find the satellites.
I've been unsuccessful at finding the satellites but there are quite a few trees, even though the branches are bare. I can't even get a single blip to come up, it just says 0%. I have an app finder and I have the dish pointed in the right direction, set the azimuth and elevation based on zip code etc.
I'm here because I want to make sure my connections are right and it's just that I'm in a lousy area to find a good satellite view. It's super frustrating since it's worked before elsewhere where I had trees. Just hoping I have it hooked up right this time.
Thanks for the help.
