kk5fe
So I’ve done several slide adjustments in the past but this one has me sort of stumped. Hopefully my description will be good enough but I can post photos if need be but it won’t be till later.
I have a Puma with two slides. Both are Lippert under the floor rack and pinion type. Front (living room) slide works perfectly. The bedroom I just noticed and probably has been like this from day one. It’s only a couple months old....
The slide seems ok as far as side to side and top and bottom. The issue is that when I slide it out, the bottom hits the wall first and stops before the top has had a chance to completely seal the top. There is no gap at the bottom and enough gap at the top (equal on both sides) I can almost put my finger into. If I push on the top of the slide, it shakes so there is room to go.
The only adjustment I know of I’ve copied and pasted from the manual below but I’m a bit leary of doing that since it’s hitting on the bottom already. Any other thoughts? Thanks!!
Adjusting room so it seals in the OUT position
1. Locate the actuator coming through the frame.
2. On the end of the actuator, there is a threaded shaft mounted to the bracket with three nuts and a stop
can (Fig. 19).
3. Using a 1 1/8" wrench, move the 3/4" nut (Fig. 19
and, using a 1 1/16" wrench, move the nylock nut (Fig.
19C) in either direction. This will change the location of your seal going to the "out" position.
4. Make sure all nuts are tight.
can (Fig. 19).
