Just make sure it states DIGITAL reception. The older style ones are Analog only and pick up very little. Going from one of those to the King I linked above made a 100% improvement in reception. Also check to see if your trailer is already powered for an amplifier, or has an amplifier already inline as that can affect reception of the new one.
Are we just using different semantics?
Actually, there is such a thing as Digital antenna.
Digital is data. The more signal, the more data, the more data, then clearer the picture.
There are minor differences between the old style pre-digital antenna and the ones stated digital. It is in the construction of the elements. Because the digital code is buried in the analog signal, the elements have to be tighter in order to grab as much signal as it can. As mentioned above about the Winegard on Amazon, there are still pre-digital antenna being sold that while they can pick up the stations, aren't designed to grab as much signal as the newer ones.
I used to have a large 250 mile Winegard on my roof when they switched to the digital signals, and it worked, but got a lot of pixilation on some channels. Upgraded to their newly designed 250 mile antenna and now receive more clearer channels, so there is something to the "Digital" statements. I noticed that the element running down the spine is much different than the older antenna. This is the part that gathers up the signals and sends them down the cable. There was also a clear difference between the old wing antenna and the ones they sell now that look like ray guns or disks.
Ever wondered why house antenna have varying length elements? They are that way to pick up the varying wave lengths. Channels 2-13 are low frequency, and require longer elements, UHF is at higher frequency so they require shorter elements, and more of them. So while the older antenna can still pick up the analog signal, they can only gather up so much of it. This is why they state Digital on the new antenna, because they have the proper elements to gather more signal than the older ones. The older ones still work, just not as good.
Check out Winegard's newest cellular access point and wifi extender dome, the Connect 2.0 Plus. The "plus" version now includes an amplified TV, FM and AM antenna.
The cellular access and wifi extender is similar to their previous Connect 2.0 units that didn't have the TV/AM/FM antennas, and it's a great hotspot access point and it has amazingly good wifi extender capability -- going out about a mile.
The new one also has one new feature added -- band 71 for Tmobile. The Connect 2.0 does require a cellular subscription SIM card from ATT, Verizon, Tmobile or their own Winegard pay as you go plan if you want cellular access.
So all in one dome, you get cellular access using two phased antennas, wifi access and wifi extender with three MIMO antennas, *PLUS* the AM/FM/TV antenna.
About $440 direct from Winegard. Just be careful to get the WF2-95B Connect 2.0 "Plus" version, rather than the older non-"plus" version that are being unloaded on Amazon and ebay if you want the TV and radio antennas.
I now use the batwing antenna hole for my solar wires and other cables and seal it up with a rubber plug and some mastic.
Thanks for all your help.
Do you have a link for this product? I can’t find it anywhere.
