Three people
We had a sudden and heavy thunderstorm here today. I had my awning out on my Rockwood 2606WS while it was sitting in my driveway. The awning filled up with water and it collapsed the frame on one side of the awning. The frame is pretty bent up along with the fitting at the end of the awning bracket. The awning itself is also ripped. Thankfully, it didn't pull the bracket that attaches the awning to the trailer off, so there is no damage to the body of the trailer.
How difficult is it to replace the entire awning framing? Can the unit be purchased directly? and if so, how hard is it to install?
Any experiences would be appreciated.
Obviously, no one ever told you the first and second rules of Awning:
- Never leave the awning deployed if it's going to be windy. If you're not sure and you're leaving, retract it.
- Never have the outboard end (roller) level. Always have one end lower so rain runs off that end instead of puddling.
It's easiest to work on the awning if you completely remove it from the trailer. It's easy if you have three people.
Before they arrive
If this is a manual awning, set the lock lever so it doesn't wind up further.
Get onto a ladder and inspect where the top end of the awning attaches to the rain gutter. At the bottom of the rain gutter extrusion is a C-shaped channel. The top of the awning has a 1/2" hem. Inside the hem is a 1/8" steel or rubber rod. At each end of the awning, a (#4? ) screw has been driven through the extrusion to keep the rod from sliding. Remove and save these screws.
When they arrive
Explain the procedure to the helpers. You will be on the trailer roof pulling the fabric along the C-shaped channel while they each disengage an awning standard from its socket and carry it, marching along, keeping up with you. You can pull the fabric off to the front or the back, whichever way has the most room. (I had to pull a 22' awning to the front because there was no room in the back. A 16' one could have gone either way.)
Once it's down
It's helpful to set the roller down with something like a milk crate under each standard, near the roller to keep the roller off the ground. Take a picture, showing which direction the awning is wound, so you don't wind the new fabric backwards. The roller will have two C-shaped channels. In the instances I've seen, there's no hem for the rod. The fabric is just tucked into the roller and then the rod is inserted from the end. At each channel. A manual awning will also have a pull-down strap tucked into the channel. Pill the rods out, then the fabric.
Putting it back together
Putting it back together is a reversal of these steps. There are only two things to watch.
- Be very careful to get the fabric on the roller straight, so it will roll up nicely and not creep off one end of the roller as it winds.
- After the awning is completely installed, but before the screws are in place completely extend it and then roll it up several times. If it creeps to either side, pull the fabric at the roof gutter a TINY bit (1/16") to the other side and retry. Continue until the fabric rolls straight. Then put the screws in.
