Attaching things to the walls
Robsteeler66
RV LIFE Pro
Aug 25, 2023
198
Southern-ish NJ
I know people use command hooks to stick things to walls, but are there studs in the walls? I have a fiberglass laminated unit. I’m not sure what it’s laminated with, maybe someone has some insight? I’d like to make more secure attachments than adhesive. Thanks for indulging a newbie!
What’s the weight of what you’re trying to hang?
We just have some decorative hangings……we’re not into rock climbing 🧗
There are studs but finding them can be a challenge, especially if aluminum.
Another poster noted difficulty using a stud finder and I can confirm.
I've seen infrared pics show them pretty clearly in wintertime and I wonder if a laser temp gun might work too.
Command strips come in varying weigh capacities and as per their directions, can be doubled up to increase it.
JMO but anytime you're drilling into the wall, there is some unknown risk of catching a wire, so you gotta really want it.
Our trailer walls are basically thin luan covered with plasticized paper for appearance. For pictures and other lightweight items, I use a #6 Panhead sheet metal screw, about 1/2" to 3/4" max length. I find it is NOT necessary to drill the wall when using sheet metal screws. If one wants a starter hole, use a pointed awl.
As to hanging a TV on any of our walls, I wouldn't do it. There is one area designated as a TV wall, whatever that means. I still don't think it is sufficient to reliably mount a TV.
As to the 3M Command hooks, I find they eventually fail due to heat and the fact the surface is not flat.
Bob
Bob
We purchased a wall mount made for RVs that has a latch that holds it in place while moving and a small TV for the bedroom. Hubby mounted on wall where factory had a decal that said something like TV here. Been there 3 years with no problems.
I use the 3M hooks. The only ones that let go were the ones I put up and hung stuff on minutes later. I have learned if I use Isopropyl Alcohol to clean the wall and hook, allow to dry completely, apply the 3M adhesive to the hook and press to the wall. Allow to set 24 hours. Here in NC we go from below freezing to 100+ temps with little humidity to right at 100% humidity and my hooks hold. Like someone else said just make sure the hook you use is rated for the weight.
Thanks. We bought some adhesive strips already. The tv inside is no problem, I know where to mount that. I was asking if anyone had any experience with the outside wall tv mounts like in the link I posted.
Our TT already had the outdoor mount when we purchased it.
We love our TT but there are a couple of things missing that we wish it would have had, including an LP quick connect. I would have liked an outdoor kitchen of some sort, but no. It does have the coax connection and the plug for a tv, but no mount. It always seems you make some compromises no matter what.
I know what you mean. Ours was the early 2019 so no good steps, no drop down counter (had a big clunky thing with a peg leg you had to lift onto clips and no where to store), plastic sinks in the bathroom and kitchen, no water mizer and a smaller underbelly storage because they hadn't started the drop down frame yet. I just couldn't see paying a little over 8k to have those things. Pretty much have all those things except of course the bigger storage and don't have half that much in all of it.
As to your question about studs. Yes, they are there. Mine are aluminum. Yours could be aluminum or wood. Look for the brochure for yours online to find out how it was built. To locate the studs outside, go out early in the morning when the dew is out and look at the side of the rig, and the studs should stand out. (The narrow dry spots.)
Good luck.
Good luck.
Good tip! Thanks.
Good luck.
I’ll check for that. I have the app which has owners manuals, but it isn’t specific. It’s also hard to find information about my model since it’s a new floor plan. Every time I search 22 eras, I get information about Taylor Swift’s tour.
Well you can always send an e-mail to the customer service contact asking for more information. I have had pretty good luck with that, usually 2 to 3 days for a reply.
I sent an email before we even picked up our RV 3 weeks ago. I still haven’t heard anything back. 🤷🏽*♂️
While I'm not a Forest River owner, yet, I have a Flagstaff 26FKBS on order. I plan to mount on the walls on occasion, and I expect my Walabot sensor will find the aluminum studs in the laminated walls.
Welcome to the forum. I had to "Google" Walabot to see what you are talking about. It looks pretty good from the descriptions. Is it as good as the web claims?
It's nearly X-ray vision into wallboard. Not just studs, either. It shows pipes & wiring. That's why I have high hopes for the aluminum studs.
