g.spalding
Advanced Member
- Joined
- May 28, 2024
- Posts
- 33
In doing a Group 24 Lead Acid to 200Ah LiFePO4 upgrade, my battery location will move from the tongue to under the bed. A short negative battery cable can connect it to nearby inverter. (I'll be abandoning the long negative line coming from the battery box on the tongue.)
From the new battery position I plan to to run a new 10’ positive cable out to the 100A fuse on the tongue, where the old battery currently connects. The positive line from battery to inverter will end up around 24’ long in total.
** Is there any issue with having a short (18*) negative cable and s long (24') positive cable connecting the battery to inverter? **
If the positive and negative lines must be kept similar in length, I will buy a new 10’ negative cable to run from the battery and splice it to the existing negative cable at the tongue... but is it necessary?
