Relion RB300 is a 300 AH battery for $2350.00. Then there is the Ingeosolly IN-12v300AH which claims to be a 300AH battery for $568.89. Why such a huge disparity in prices? Is this a extreme example of "you get what you pay for"?
Lifepo4 is lifepo4 no matter who the manufacturer is (assuming it is not a fake). There can be differences in construction quality and in the BMS.Relion RB300 is a 300 AH battery for $2350.00. Then there is the Ingeosolly IN-12v300AH which claims to be a 300AH battery for $568.89. Why such a huge disparity in prices? Is this a extreme example of "you get what you pay for"?
This is a matter of Relion is a well know brand with US based support though I don’t know where their batteries are made
The other is the cheapest bargain basement thing you can buy. Good luck with any customer support. I don’t know the brand specifically but I bet there will be no one on the other end of the phone when you need help. And yes. You get what you pay for.
I said many times buy the best you can afford and you will never be disappointed
Thanks for the replies, folks. I believe I'll pass on the Relion. I'm now looking at a batteries from Epoch or Li Time. Looking at models with good BMS and perhaps blue tooth.
Also make sure you get low temp charging protection which means if the temp goes below freezing or a heated battery's charging threshold is crossed, the BMS won't allow the battery to charge and damage the battery.
I'm close to pulling the trigger on this battery. It advertises that it has "HEATED - Internal heating allows for charging in sub-zero conditions".
NO and Yes
depending on what you call equalize
a) Two batteries that are going to be joined together should be of equal charge
best way to equal-ize them is to fully charge each seperately
Then they can be joined
Serial or Parallel you want them at the same voltage if possible...
b) Single battery .... equalize the cells within the battery
Usually called Balancing ... a good BMS should ensure the 4 cells in a 12v battery are at the same voltage.
Balancing usually only happens when the battery is 95% or more charged... Top balancing
To give my cells the most time to balance, I have set my battery to balance the cells whenever they are 3.4 (or higher) ... Balancing will continue when charging current drops Off and the battery is being discharged
PS.. addition
Balancing need only happen once in a while... so charging the batteries to 100% at least every 2 WEEKS or so is good for them
More often is better ...
